Lower Grille
RE: Lower Grille
when i was prototyping the street scene stuff i tossed my lower grill after about 6 months because i needed the room for the remodle. then of course they came out with the center light OEM kit and i prototyped that. and liked it and kept it. i got a replacment from my bud at the dealer. i can get another one and you can pick it up sat when you come over . ill even pop it in. if i remember it was under 25 bucks. ill check if you want.
RE: Lower Grille
pete are you working today? swing buy today and we will check it out. also james santa barbra is not that far you should come down next saturday for the 3 x-charger installs. and we will pop in yours and pete's. ill call tomarrow and get a price
RE: Lower Grille
I just got it back on it looks like one of the brackets some how bent so i bent it back and sealed the little cracks it caused on it with some glue. Seems to be fine now ill take it for a high speed test later on.[8D] and hey tom where did you get your seat covers from?
RE: Lower Grille
had them done down the street its tha actual seat i removed them and took them in. had them back in the afternoon as for the ponies thats a done deal the guy dosent make them any more after ford called him.
RE: Lower Grille
I have plans this weekend so I won't be able to make it. If you find out any info on the grille please let me know. I need one for sure. I just need a stock lower grille, but if it comes upper and lower I won't cry over it. Thank you.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
