First Dyno
Old 06-16-2007, 03:38 PM
GIDDEUP
GIDDEUP's Avatar
Default First Dyno
Well I just got back from the dyno and was a little surprised at the numbers I put down. I was thinking I'd be somewhere in the high 170/ low 180's, but came in at a respectable 196 HP/ 220 Torque. Not too bad for a CAI and exhaust.
http://i38.photobucket.com/albums/e1...et06-16-07.jpg
GIDDEUP is offline
Old 06-16-2007, 03:55 PM
kidrobotzero
kidrobotzero's Avatar
Default RE: First Dyno
thats pretty good. so your only mods are a cai and a axleback? no tune or anything else? r u stick or auto.
kidrobotzero is offline
Old 06-16-2007, 03:58 PM
GIDDEUP
GIDDEUP's Avatar
Nope no tune yet. It's a stick.
GIDDEUP is offline
Old 06-16-2007, 04:46 PM
sdsguy
sdsguy's Avatar
why is your torque curve's peak so early? it almost looks like you got an electric engine in there. normally there should be a climb to the peak, in this dyno it looks like all your torque came in at once.
sdsguy is offline
Old 06-16-2007, 09:51 PM
autorat67
autorat67's Avatar
what axelback and CAI do you have on your car?
autorat67 is offline
Old 06-17-2007, 01:19 AM
rmays06
rmays06's Avatar
Very nice numbers witht he mods you have, tune that bad boy and watch it turn into a different car.
rmays06 is offline
Old 06-17-2007, 10:52 AM
GIDDEUP
GIDDEUP's Avatar
Just the AEM Brute Force CAI and GT takeoff exhaust with H-pipe.
Not sure about the torque curve. Might just be where they started sampling from. you'll notice I was already at 3500 RPM.
GIDDEUP is offline
Old 07-21-2007, 10:58 PM
Sancho805
Sancho805's Avatar
just a brute force and dual exhaust h-pipe? wow, if this is accurate then i guess i will be saving my money and keep my AEM. looks like custom tunes is all i need. i was really debating on whether i should save for the C&L and then get custom tunes but i guess, based on your dyno, i can get my tunes right away.
Sancho805 is offline
Old 07-21-2007, 11:09 PM
94Blk5.0
94Blk5.0's Avatar
Factor in a 10-15% driveline loss with a 5speed and you should be looking at 225 HP at the flywheel with a 15% loss give or take a few HP's. The tune would be very benefical with your set up. I would guess 10-15 HP.
94Blk5.0 is offline
Old 07-22-2007, 05:45 AM
06jalmustang
06jalmustang's Avatar
Really off topic but are you from ohio or Idaho, the reason i ask is cause your plates look just like idahos? If you are from idaho which part i used to live in mountain home
06jalmustang is offline
Quick Reply: First Dyno
