Exhaust Rattle
Exhaust Rattle
I've read where many owners have been having problems with their exhaust rattling, especially after they have duals installed.
So far, I have not had any problems.....knocking on wood!
RE: Exhaust Rattle
I think any rattles from exhaust would have to come from a bad installation. Ur mechanics/installer probably didn't tighten something all the way or clamp something he had to clamp. The dash area I think might be a Ford recall, and u could probably get that fixed for free or it might have to do with u having a stock driveshaft, at what mph/rpm do u have the rattle?
RE: Exhaust Rattle
It's not a dash rattle, it just sounds like it is coming from the dash/shifter area. My dealership fought with it for 4 trips to the service center, it got better but not gone and they only thing that helped was when they messed with the exhaust.
Ford tech is coming Monday to the dealership to take a shot at it.
RE: Exhaust Rattle
ORIGINAL: ODDYSEY
RE: Exhaust Rattle
ORIGINAL: Torch_Vert
Did they check theexhaust hangersfor the Y-pipe? There's a TSB for those getting loose and causing a center stack rattle. The TSB calls for putting large hose clamps over them to kill the rattle.
ORIGINAL: ODDYSEY
RE: Exhaust Rattle
ORIGINAL: ODDYSEY
Yep they did that and it helped ALOT but it's still there. Now it's only there when you slow down right before you stop, and ever so often it comes back for a second then leaves.
ORIGINAL: ODDYSEY
RE: Exhaust Rattle
Sound's like the exhaust is loose. U need to take it to someone who will either tighten the clamps already on it, put more clamps on it(stronger one's), or just replace all the clamps and see if that's it.
RE: Exhaust Rattle
ORIGINAL: SteelStang05
09-24-2015 09:18 PM
