How many quarts of oil do we need...
Yes, very newbie question but is it 6 just like the GT? I know we need SW-30 though. Looked through the manual and saw nothing. Also, are the oil filters interchangeable? I want to go with Mobil 1 (M1-210)
RE: How many quarts of oil do we need...
5 qts is what the owner's manual says. GT is 6 qts. You always want to change the filter when you change the oil. Filters are somewhat to specific to each model of car. I use a Bosch 3410(?) filter and Mobil 1 5W-30.
Gotta be careful with too much oil. 5 qts with new filter, 4 qts with full old filter left in place is Spec. if you put 6 in you may be overloading oil pressure guidlines and blow seals...(more oil in the pan does increase oil pressure)..Also will void warranty on oil related damage if they pull 6 qts out after you tow it to the dealer for warranty replacement...
Just don't put too much in. Won't hurt anything to have it not quite plum full, but having it too full is a different story. Owner's manual says 5, I'd stick with that.
EDIT: the spec sheet from ford actually says 4 quarts, and 1 quart with the filter, for a total of 5 quarts. http://www.fileden.com/files/2008/3/...ng%20Specs.pdf
Page 4 under "Engine - Lubrication System" ... Left hand column is 4.0 v6, right-hand column is 4.6 v8.
