How to install a fuel pressure gauge? - Page 3 - MustangForums.com
Sponsored by:
Sponsored by:
Old 01-18-2013, 03:25 PM   #21
Topless Stang
Topless Stang's Avatar
You were right. Once the sender arrived today I was able to see how everything fits together. I have one problem though. I can't get the nipple off. The part to be removed is just the threads, or does the entire top come off? I tried removing just the threads and then moved to the nut, but I didn't want to apply too much pressure...either way I tried it didn't budge, all that happened was the metal started to flake off.
Topless Stang is offline   Reply With Quote
Old 01-18-2013, 08:17 PM   #22
Topless Stang
Ok...do I need to apply heat to get the nipple off? It won't budge. The metal on the rest of the brass piece has flakes off and the nipple doesn't move. I wanted to post up here before I tried apply heat with my mapp torch...
Old 01-19-2013, 09:14 AM   #23
Topless Stang
It's a lost cause now. That was a big waste of money...well it was only $25, but it was still a waste. Any idea if I can get something locally that will do the job?
Old 01-19-2013, 11:01 AM   #24
157dB
Cut & Paste Expert
157dB's Avatar
Woops.
Shoulda woulda drilled it out.
157dB is offline   Reply With Quote
Old 01-19-2013, 01:22 PM   #25
Topless Stang
I picked up a real fuel rail adapter FTW!
Old 01-19-2013, 04:23 PM   #26
GrayPony
Wow, what did you use... a hammer and a pair of pliers.
Proper tools would have been, a correct size line or box wrench and a soft jaw vice to hold the block.
Good luck on the fuel rail adapter, I purchased 2 and neither fit my ralis.
GrayPony is offline   Reply With Quote
Old 01-19-2013, 04:46 PM   #27
Topless Stang
I used a vice with vice grips, open wrench, box wrench, deep socket, channel locks, etc...no matter what I tried it wouldn't budge. Getting a real fuel rail adapter made for a much easier install. I already put the sender & adapter in place...no leaks! I just swapped my Boomtubes for a set of GT Takeoffs because the drone drove me insane...now I'm off to run lines for boost/vac, fuel pressure & wideband.
"Death Trap" my new 84 GT build thread 67LimeCoupe 5.0L General Discussion 45 11-25-2015 09:55 PM
What's considered normal oil pressure? yurizx6r 5.0L (1979-1995) Mustang 49 09-07-2015 07:40 PM
1997 Cobra Fuel Pressure? Scottyboy187 SVT Forums 3 09-02-2015 11:12 AM
Fuel issues... any ideas?! timeformiller44 4.6L (1996-2004 Modular) Mustang 4 08-26-2015 01:03 PM
Oil pressure freak out yurizx6r 5.0L (1979-1995) Mustang 14 08-11-2015 08:50 AM
2005, 40, adapter, fuel, gauge, hot, instal, install, mustang, pressure, rail, s197, tomhook, v6
