Steering Stops??
Steering Stops??
Has anyone that has changed their factory 16" wheels to factory 18" polished, chrome, or black bullitts have to use steering stops as stated on Ford Racing web site.
From Ford Racing web site:
http://www.fordracingparts.com/parts...tKeyField=8977
Note: For vehicles with 16" wheels from the factory: -installing 17" x 8" wheels, use steering stop 4R3Z-3932-BA -Installing 18" x 8.5" or 18" x 9.5" wheels, use steering stop 6R3Z-3932-CA
For vehicles with 17" wheels from the factory: -installing 18" x 8.5" or 18" x 9.5" wheels, use steering stop 6R3Z-3932-CA
RE: Steering Stops??
https://mustangforums.com/m_4819171/mpage_1/key_/tm.htm
I am also going to put 18x8.5 OEM Polished Bullitts wrapped in 255/45-18s on my V6.
I dont see needing the steering stops as most will tell you that they are not needed
But youwill need to change the V6 caliper brackets on the front to GT caliper brackets
along with GT rotors to maintain proper clearance between the wheels spokes and the
brake caliper brackets.
You need 2 caliper brackets part #6R3Z-2B134-B, the same left and right.
The biggerGTrotors are available as take-offs or aftermarket.
https://mustangforums.com/m_4718939/tm.htm
V6 16x7STOCK RIMS
[IMG]local://upfiles/69445/FF16B0F1B55948D9A0E5BE2EDE2987D9.jpg[/IMG]
17x8 OEMBULLITTS
[IMG]local://upfiles/69445/E7A4DFCCB9BF4B308F9E85808FA43529.jpg[/IMG]
18x8.5 OEM BULLITTS
[IMG]local://upfiles/69445/431835FAF3D74DFA9F3B511EDFC16473.jpg[/IMG]
V6 16x7STOCK RIMS
17x8 OEMBULLITTS
18x8.5 OEM BULLITTS
The only time I miss not having them is pulling in or out of a parking spot. If you cut the wheel all the way to one side or the other it makes a nasty noise. Usually not a problem unless things are tight.
As far s the caliper brackets I just shaved them down about a 1/16" or so where they rub the back of the wheel.
I would recommend getting them both if you can.
Is this the case only with OEM factory 18 chrome, polished, or black bullitts or with any 18" wheels? If I ordered 18" deep dish bullitts whether they are chrome or black from American Muscle or Discount Tire, will I have to have any spacers or steering stops or can I just bolt them on and drive?
ORIGINAL: silstang23
If you like the Ford Racing 18" Bullits and you are a V6, its worth the Brake upgrade alone, bigger wheel, bigger brake......it's all plus!
I personally like the Ford Racing over all the other Aftermarket Bullits....IMO!
It's all what youLike!!!
ORIGINAL: jimkaray
Aftermarket rims dont apply here. They fit just fine.
18, 2008, 4r3z3932ba, 6r3z2b134b, 6r3z3932ca, buy, ford, installing, kit, needed, rims, steering, stop, stops, v6
