Vibrations at idle..
Old 06-14-2008, 05:01 PM
machina
machina's Avatar
Default Vibrations at idle..
so occasionally, not all the time.. but every so often i'll get a really bad vibration that sounds like it's coming from the back end of the car.. it'll idle around 1000RPM and it won't go away unless i step on the gas. sounds like it's coming from the exhaust if i had to say.. any ideas what this could be?
machina is offline
Old 06-14-2008, 10:03 PM
AmericanICON
AmericanICON's Avatar
Default RE: Vibrations at idle..
Do you have an aftermarket exhaust system?
AmericanICON is offline
Old 06-15-2008, 02:52 PM
machina
machina's Avatar
mm.. i have the ninosport dual exhaust conversion with GT takeoffs.. that's all
machina is offline
Old 06-15-2008, 03:25 PM
Maverickaf17
Maverickaf17's Avatar
Same thing happens to me. I have older Flowmaster 40's.
But, nothing seems wrong, just an annoyance.
Maverickaf17 is offline
Old 06-15-2008, 06:17 PM
thedragon
thedragon's Avatar
same here i just firgured it was resonance drone but its pretty bad to be that. I have a single flowmaster american thunder muffler
thedragon is offline
Old 06-15-2008, 07:03 PM
Torch_Vert
Torch_Vert's Avatar
Check all the exhaust hanger bolts (if you haven't already)
Also check that the exhaust expanding when it's hot (it'll actually stretch a bit as it warms up) isn't causing the hanger rods to touch either the metal part of the hanger, or the sheetmetal behind the rear bumper. Had all of the above at various times with aftermarket exhaust on my car.
Torch_Vert is offline
mtgldr
02-03-2024 09:00 PM
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
mdj89
09-23-2015 08:49 AM
ccdguy
09-19-2015 05:20 PM
Quick Reply: Vibrations at idle..
