MGW short shifter
Old 06-26-2008, 12:36 AM
vb101
vb101's Avatar
Default RE: MGW short shifter
Shift stops are not necessary since the T5 has built in shift stops. I have an MGW and after two weeks it's much smoother than the Hurst I had before and makes no noise at all. As a matter of fact it shifts more smoothy than it did stock and with about 25% shorter throw at that.
vb101 is offline
Old 06-26-2008, 01:04 AM
NocturnalV6
NocturnalV6's Avatar
I would hope that MGW would shift better than stock lol. No like trying to shift a crowbar through bricks
NocturnalV6 is offline
Old 06-27-2008, 07:26 PM
vancebreck
vancebreck's Avatar
Like most of the others the hardest time I had was removing the old shifter. I have mine set to 7 turns and I like it.
The only thing I would stress is the point in the instuction where it talks about the shifter pivoting freely with the transmission (step 6). It was strange at first. Just after shifting gears I can feel the shifteralmost surging back and forth. I called George cause I was concerned I F'd something up. That is the movement the was speaking about.
Good luck on the install. Did you get a new shift **** as well or stick with the stock ****?
vancebreck is offline
Old 06-28-2008, 03:30 PM
WeMowMuppets
WeMowMuppets's Avatar
I stuck with the stock shift **** for know. What about you.
WeMowMuppets is offline
Old 06-28-2008, 07:33 PM
vancebreck
vancebreck's Avatar
I started with the stock then got tired of it in about 2 days. Went ahead and upgraded to the MGW black classic ball assembly with the satin chrome (just like the pic on their website). Looks much better I think.
firehorse02
11-16-2015 11:28 AM
jrrhd73must
10-02-2015 09:17 PM
Explosive
10-02-2015 07:45 AM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
Quick Reply: MGW short shifter
