Borla stingers vs FFRP GTA/Bs
#21
RE: Borla stingers vs FFRP GTA/Bs
If i went with the Stingers all I would need then is to order an X pipe and the FFRP stingers correct?
**EDIT** I just got back from the dealer and I can get the GTA kit for only 369 so I think that is worth it.
#25
ORIGINAL: Maverickaf17
And, does anyone have a clip of the GTAs? A good one? I've never heard them before. And if I have, its been from a ****ty clip.
#26
ORIGINAL: VictoriaRR
Clips are helpful but I've found that hearing these exhausts in real life is the best way to judge them.
Even if it is loud as long as it is deep.
ORIGINAL: 1badV6
will the stingers cause torque loss over a GTA style muffer with more backpressure?????
If you go with an H pipe you will feel a bit of loss in torque at the low end. It's nothing major, and it definitely doesn't take away from the enjoyment of the car (especially because of how wicked it sounds), but it is there and you can feel it somewhat. If you go with an X pipe the sound won't be quite as amazing as with the H (still very, very good sound, but there is a slight difference), but there is no noticeable loss in backpressure from what I can tell when taking off.
#28
ORIGINAL: thenatural
What do I need to do the conversion from a single to true dual?? Just the axel-backs and an X or H pipe? are there other pipes needed? I feel stupid
