Taco Bill lowering springs HOW TO
Old 08-10-2008, 10:56 PM
thuxel
thuxel's Avatar
Default Taco Bill lowering springs HOW TO
Has anyone used Taco Bill's how to for lowering springs?
If you have, did you have any problems?
Also what type did you use?
thuxel is offline
Old 08-11-2008, 07:48 AM
vancebreck
vancebreck's Avatar
Default RE: Taco Bill lowering springs HOW TO
I used it about a month ago to install a set of Ebiach Pro-kit springs. Its an excellent write-up and if you follow it you should have no problems.
I completed the rear spring install in about 30 min. The fronts took longer but there is more involved. My two biggest notes about the front install concern the spring compressor and supporting the brake assembly. The spring compressor Taco Bill has is top notch. I took the "Rent-a-tool" route from Autozone and just about threw out my shoulder from all the racheting. And I was confused as to how he supported the brake assembly with the string. There is nothing in the wheel well to tie the string to. I finally just took an extra jack stand I had and used that to keep the assembly from moving.
At the time of the installation I had both the service manual write-up and Taco Bill's. I refered to Taco Bill's more often and wound up just using the service manual as a spot check.
vancebreck is offline
Old 08-11-2008, 08:30 AM
thuxel
thuxel's Avatar
Thanks!
I just wanted to be sure.
thuxel is offline
Old 08-12-2008, 02:57 PM
harlanb1
harlanb1's Avatar
Taco Bills writeup will be the best writeup you will find for changing out the springs.
The only problem I had was that I did not know which way the springs went in as I had different springs than the writeup. I had to call the manufacter to make sure.
Took me 35 minutes from wheels up to wheels down.
You cannot go wrong with his writeup.
harlanb1 is offline
lincolnshibuya
07-05-2020 03:05 AM
UrS4
10-03-2015 06:23 AM
BeatnikFink
10-01-2015 08:00 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Taco Bill lowering springs HOW TO
