Exhaust System
ODDYSEY Definitely going to recommend the FRPP V6 dual exhaust kit. It is high quality, sounds great, looks great and I installed mine in my garage (was a little tricky, but do-able).
I have not ever heard of throwing CELs with just
cat back exhaust change. No exhaust sensors to
satisfy after the cats.
Well, I would have to recomend my own set up to you, you will have to go to a custom mufflers shop to get it done, but I would get Flowmaster 40's, just regular 40's. The tips play a big role on these mufflers cause of the position on the car. So get you atleast 3inch becuase they are the only toner element you have after the mufflers. Also I would recomend Headers, the Chinese Ripoffs on Ebay will work, and if your handy with a wrench than you can do them yourself, I did. You will need some resonators or something on the pipes thought to kill the drone cause I just have true duals and they will drone like hell on the interstate.
I am going to put on a Xpipe and some resonators before long, and hope to clean some of that up. Its the 4.0 that I have heard yet thought with that setup
If you are looking for mildy agressive tone the FRPP kit is for you. It is tame at idle, but it attracts attention at WOT. You can get an X/H pipe and duals from Pypes that will be MUCH louder, (and cheaper) but you will have drone issues.
09-10-2015 08:39 PM
