Going to buy a V6 2007
I have no problem in snow with weight in the back and the manual tranny.
Search some threads for water intrusion issues, coming in on the passenger side. You would likely be able to notice dampness or even water damage / mold smell if you feel the carpets on that side. I did not have this issue, but many have, there is a TSB fix I think.
I have 112K on my '05 daily driver with only one trip back to dealer for a frozen parking brake.
I definitely do not want a MUSTY MUSTANG!! I will check the specific car I will test drive. It might rain today here, it may be a good time to go look at the car. Seems there MAY BE a lot of other pesky issues too.. but then again there are on every car.
Interesting:
http://www.alldatadiy.com/TSB/19/071917ev.html
Automotive Recall and Technical Service Bulletin Titles for 2007 Ford Mustang V6-4.0L VIN N.
TSB Number & Issue Date TSB Title
08C02 FEB 08 Recall - Occupant Crash Protection Non-Compliance
08-26-7 JAN 09 Body - Water Leak Onto Front Floor Area
08-24-10 DEC 08 Interior - Rattle From Dash/A-Pillar Area
08-23-4 NOV 08 Drivetrain - Shudder On Acceleration
08-21-7 OCT 08 Body - Power Window 'Bounce-Back' Diagnostics
08-21-6 OCT 08 Drivetrain - Excessive Rear Axle Whine
08-17-3 SEP 08 Body - Convertible Top Quarter Glass Separation
08-9-2 MAY 08 Lighting - Uncommanded Perimeter Lighting
08-8-5 APR 08 M/T - 4th Gear Knock/Rattle on Light Acceleration
08-3-4 FEB 08 Exhaust System - Rattle/Buzz From Floor Console Areas
08-2-4 FEB 08 M/T - Shifter Boot Ticking Noises
07-23-1 NOV 07 Suspension - Front End Grunt/Creak/Squeak/Chirp on Bumps
07-21-12 OCT 07 Fuel System - Difficult Fuel Fill/Nozzle Shuts OFF
07-20-3 OCT 07 Convertible Top - Tension Cable Tick/Pop/Rattle
07-19-1 OCT 07 Body - Premature Convertible Top Wear
07-18-2 SEP 07 Suspension - Front Suspension Rattle/Chuckle Sounds
07-17-6 SEP 07 Audio System - Buzz/Rattle From Door Speaker/Door Panel
07-17-8 SEP 07 Body - Various Convertible Top Concerns
07-16-7 AUG 07 Body - Exterior Door Handle Not Flush/Loose/Rattles
07-12-3 JUN 07 Restraints - Control Module DTCs & Associated Fault PIDs
07-10-3 MAY 07 Air Bag System - Warning Lamp ON/DTC 2295/Code 22
07-6-7 APR 07 Body - Spoiler Contacts Deck Lid
07-5-8 MAR 07 Battery - Battery Eye Function/Charging/Service
07-5-13 MAR 07 Battery - Discharges After Vehicle Storage
07-4-3 MAR 07 Interior - Leather Wrapping On Steering Wheel Is Loose
07-1-7 JAN 07 Steering - Mercon V(R) Fluid Usage
06-26-2 JAN 07 Interior - Carpet Removal/Replacement Procedure
06-26-1 JAN 07 M/T - Mercon(R) V ATF Usage Information
06-25-15 DEC 06 Body - Aluminum Body Panels - Corrosion
06-25-3 NOV 06 Audio System - Pioneer Navigation Radio - Seek Inop
06-21-19 OCT 06 A/C - Heater Core Electrolysis/Leakage
06-17-8 SEP 06 Electrical - Wiring Harness Replacement Guidelines
http://www-odi.nhtsa.dot.gov/tsbs/
Search Results
Report Date : May 26, 2009 at 09:09 AM
Search Type : VEHICLE
Year : 2007
Make : FORD
Model : MUSTANG
Results : 16 | All records displayed
Make : FORD Model : MUSTANG Year : 2007
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Number : 07103 Date of Bulletin :
NHTSA Item Number : 10021905
Component : AIR BAGS
Summary :
AIR BAG WARNING LAMP ON - DTC 2295 IN RESTRAINTS CONTROL MODULE AND LAMP FLASH CODE 22. *KB
Check to Request Research. Submit below.
Service Bulletin Number : 01011901 Date of Bulletin :
NHTSA Item Number : 10020921
Component : SUSPENSION:REAR:SHOCK ABSORBER
Summary :
REAR SHOCK SERVICE PROGRAM. *KB
Service Bulletin Number : TSB-08-26-7 Date of Bulletin : MAY 01, 2009
NHTSA Item Number : 10028507
Component : STRUCTURE:FRAME AND MEMBERS
Summary :
FORD: VEHICLE MAY EXHIBIT A DIFFICULT TO DIAGNOSE WATER LEAK IN THE FRONT FLOOR AREA. MAY BE CAUSED BY LOOSE GROMMETS AND/OR SEALER SKIPS AROUND THE COWL AREA, LOOSE A-PILLAR WINDOW WEATHERSTRIP RETAINER. *PE
Summary :
Component : STRUCTURE:BODY
Summary :
Component : STRUCTURE:BODY:ROOF AND PILLARS
Summary :
Service Bulletin Number : 20523 Date of Bulletin : NOV 01, 2008
NHTSA Item Number : 10028168
Component : SEAT BELTS:FRONT:RETRACTOR
Summary :
FORD: AIRBAG LIGHT-PRETENSIONER PIGTAIL KIT AVAILABLE. VEHICLES MAY EXHIBIT AIRBAG LIGHT WITH B2292 HARD FAULT CODE POINTING TOWARD SEAT BELT PRETENSIONER. REPLACE BODY WIRING HARNESS CONNECTOR. *PE
Service Bulletin Number : TSB-08-9-2 Date of Bulletin : OCT 23, 2008
NHTSA Item Number : 10026383
Component : EXTERIOR LIGHTING:TAIL LIGHTS
Summary :
FORD: UN-COMMANDED PERIMETER LIGHTING. VEHICLES MAY EXHIBIT UN-COMMANDED PERIMETER LIGHTING FEATURE (HEAD, PARK AND SIDE MARKER LAMPS) DUE TO WATER INDUCED SHORT TO GROUND IN THE DOOR DISARM SWITCH. *PE
Component : EXTERIOR LIGHTING:BACK UP LIGHTS
Summary :
Component : EXTERIOR LIGHTING:HEADLIGHTS
Summary :
Service Bulletin Number : TSB-08-9-6 Date of Bulletin : OCT 23, 2008
NHTSA Item Number : 10026386
Component : POWER TRAIN:MANUAL TRANSMISSION
Summary :
FORD: 4.6L WITH TR3650 MANUAL TRANSMISSION; CLASH OR RASPY FEEL; SHIFTING INTO 2ND AND/OR 3RD GEAR. CONDITION MAY BE MORE PRONOUNCED WHEN THE TRANSMISSION IS COLDER THAN 40 DEGREES F (5 DEGREES C). *PE
Service Bulletin Number : TSB-07-14-6 Date of Bulletin : JUN 03, 2007
NHTSA Item Number : 10027146
Summary :
FORD: IN SOME VEHICLES THERE MAY EXHIBIT A DIFFICULT DIAGNOSE OF A WATER LEAK IN THE FRONT FLOOR AREA. *PE
Component : STRUCTURE:BODYOOR
Summary :
Summary :
Service Bulletin Number : 04032007 Date of Bulletin : APR 03, 2007
NHTSA Item Number : 10021732
Component : POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary :
REFLASHING THE POWERTRAIN CONTROL MODULE (PCM). *KB
Service Bulletin Number : 19296 Date of Bulletin : AUG 01, 2006
NHTSA Item Number : 10021059
Component : SERVICE BRAKES, AIR:ANTILOCK:ABS WARNING LIGHT
Summary :
ABS WARNING LAMP ON. GROUND G101. *KB
Report Date: May 26, 2009 at 09:15 AM
Search Type: VEHICLE
Make: FORD
Model: MUSTANG
Model Year: 2007
http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
Results : 3 | All records displayed
Make: FORD Model: MUSTANG
Model Year: 2007
Manufacturer: EIBACH SPRINGS, INC. Mfr's Report Date: OCT 16, 2006
NHTSA CAMPAIGN ID Number: 06E089000 N/A
NHTSA Action Number: N/A
Component: SUSPENSION:FRONT
Potential Number of Units Affected: 400
Summary:
CERTAIN AFTERMARKET EIBACH BRANDED FRONT STRUTS ONLY, PART NO. 35101.8001, AND EIBACH BRANDED FRONT STRUTS AS SUSPENSION KITS, PART NOS. 35101.840, 35101.680, 35101.780, 35100.680, 35100.780, 4.10135.680, AND 4.10035.780, SOLD FOR USE ON 2005 THROUGH 2007 FORD MUSTANG VEHICLES. THE FRONT ANTI ROLL BAR ATTACHMENT BRACKET ON THE FRONT STRUT CAN SEPARATE FROM THE STRUT HOUSING DUE TO INCONSISTENT WELDING. THIS COULD RESULT IN A CLUNKING NOISE AND OR POOR HANDLING IN EXTREME OR EMERGENCY MANEUVERS.
Consequence:
IF THE BROKEN BRACKET CONTACTS THE TIRE, SIDEWALL DAMAGE CAN OCCUR, POSSIBLY RESULTING IN A VEHICLE CRASH.
Remedy:
EIBACH WILL NOTIFY OWNERS AND OFFER TO PROVIDE NEW STRUTS FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON DECEMBER 1, 2006. OWNERS MAY CONTACT EIBACH AT 951-256-8300.
Notes:
THIS RECALL ONLY PERTAINS TO AFTERMARKET EIBACH BRANDED FRONT STRUTS AND SUSPENSION KITS AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON FORD MUSTANG GT VEHICLES MANUFACTURED BY FORD MOTOR COMPANY. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2007
Manufacturer: FORD MOTOR COMPANY Mfr's Report Date: FEB 21, 2008
NHTSA CAMPAIGN ID Number: 08V082000 N/A
Component: AIR BAGS:FRONTAL
Potential Number of Units Affected: 434593
Summary:
FORD IS RECALLING 434,593 MY 2008 MUSTANG VEHICLES FOR FAILING TO COMPLY WITH ONE OF THE NECK INJURY REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 208, "OCCUPANT CRASH PROTECTION," FOR AN UNBELTED 5TH PERCENTILE FEMALE SITTING IN THE PASSENGER SEAT WHILE IT IS IN THE FULL FORWARD POSITION.
Consequence:
DURING AN AIR BAG DEPLOYMENT, IF A SMALL FEMALE IN THE FRONT PASSENGER SEAT IS NOT WEARING THE SAFETY BELT, AND HAS THE SEAT IN THE FULL FORWARD POSITION, THERE MAY BE AN INCREASED POTENTIAL FOR A NECK INJURY.
Remedy:
DEALERS WILL REPROGRAM THE RESTRAINT CONTROL MODULE FREE OF CHARGE. THE RECALL BEGAN ON MARCH 3, 2008. OWNERS MAY CONTACT FORD AT 1-866-436-7332 OR THROUGH EMAIL TO WWW.OWNERCONNECTION.COM.
Notes:
FORD RECALL NO. 08C02. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2007
Manufacturer: SABERSPORT Mfr's Report Date: MAR 28, 2009
NHTSA CAMPAIGN ID Number: 09E012000 N/A
Component: EXTERIOR LIGHTING
Potential Number of Units Affected: 16270
Summary:
SABERSPORT IS RECALLING 16,270 COMBINATION CORNER AND BUMPER LAMP ASSEMBLIES OF VARIOUS PART NUMBERS SOLD FOR USE AS AFTERMARKET EQUIPMENT FOR VARIOUS PASSENGER VEHICLES. THESE HEADLAMPS FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THESE LAMPS DO NOT CONTAIN THE REQUIRED AMBER SIDE REFLECTORS.
Consequence:
DECREASED LIGHTING VISIBILITY MAY RESULT IN A VEHICLE CRASH.
Remedy:
SABERSPORT WILL NOTIFY OWNERS AND OFFER A FULL REFUND FOR THE NONCOMPLIANT COMBINATION LAMPS. THE SAFETY RECALL BEGAN ON MAY 11, 2009. OWNERS MAY CONTACT SABERSPORT AT 1-909-598-7589.
Notes:
THIS RECALL ONLY PERTAINS TO AFTERMARKET REPLACEMENT EQUIPMENT AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON VEHICLES PRODUCED BY THE VEHICLE MANUFACTURER. IN ORDER TO DETERMINE IF YOUR AFTERMARKET LAMP ASSEMBLY IS AFFECTED BY THIS NONCOMPLIANCE, PLEASE REVIEW THE LIST OF MODEL NUMBERS PROVIDED TO US BY SABERSPORT. THE LIST CAN BE FOUND UNDER "DOCUMENT SEARCH" LOCATED AT THE BOTTOM OF YOUR SCREEN. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Report Date : May 26, 2009 at 09:19 AM
Year : 2007
Make : FORD
Model : MUSTANG
http://www-odi.nhtsa.dot.gov/defects/
Results : 1 | All records displayed
NHTSA Action Number: N/A NHTSA Recall Campaign Number:
PE08060 N/A
Year : 2007
Component :
TIRES:VALVE
Date Investigation Opened : October 14, 2008
Date Investigation Closed : April 9, 2009
Summary:
ON OCTOBER 14, 2008, ODI OPENED PE08-060 TO INVESTIGATE ALLEGATIONS OF CRACKED AND LEAKING SNAP-IN TIRE VALVES IN MODEL YEAR (MY) 2007 VEHICLES MANUFACTURED BY FORD MOTOR COMPANY. THE VALVES WERE SUPPLIED TO FORD BY TOPSEAL AUTO-PARTS, A SUBSIDIARY OF THE SHANGHAI BAOLONG AUTOMOTIVE CORPORATION IN CHINA. VALVES MADE BY TOPSEAL FOR AFTERMARKET SALE WERE THE SUBJECT OF TWO RECENT SAFETY RECALLS BY TECH INTERNATIONAL (08T-018) AND DILL AIR CONTROLS (08T-028), THE LATTER OF WHICH WAS INVESTIGATED BY ODI IN PE08-036 AND EA08-022.
Interesting:
Search Results
Year : 2007
Make : FORD
Model : MUSTANG
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Make: FORD
Model: MUSTANG
Model Year: 2007
Model Year: 2007
Summary:
Consequence:
Remedy:
Notes:
Model Year: 2007
Summary:
Consequence:
Remedy:
Notes:
Model Year: 2007
Summary:
Consequence:
Remedy:
Notes:
Year : 2007
Make : FORD
Model : MUSTANG
PE08060 N/A
Year : 2007
Component :
TIRES:VALVE
Summary:
For comparison I looked up a supposedly incredibly reliable 2007 Subaru Impreza and there were no recalls on the ODI site, but there was one TSB:
Report Date : May 26, 2009 at 10:24 AM
Year : 2007
Make : SUBARU
Model : IMPREZA
Make : SUBARU Model : IMPREZA Year : 2007
Manufacturer : SUBARU OF AMERICA, INC.
Service Bulletin Number : 02-104-08 Date of Bulletin : MAR 19, 2008
NHTSA Item Number : 10024965
Component : ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE
Summary :
INTAKE MANIFOLD MODIFICATION. *NJ
But when I looked on Alldata I found more- but you cannot see the full reports without paying money:
http://www.alldatadiy.com/TSB/55/0755aw52.html
Automotive Recall and Technical Service Bulletin Titles for 2007 Subaru Impreza F4-2.5L SOHC.
11-91-08 DEC 08 Engine Controls - DTC P0607 Diagnostic Information
07-64-08 DEC 08 Body - Front Power Window Motor/Harness Change
01-167-08 SEP 08 Vehicle - Recommended Fluids/Chemicals
11-86-08 SEP 08 Engine Controls - Engine Surge While Coasting
09-52-08 AUG 08 Cooling System - Coolant Comes Out Of Reservoir
16-63-99R APR 08 A/T - Remanufactured 4EAT/4DAT/5AT Program
02-104-08 MAR 08 Engine - Intake Manifold Modification
15-126-07 FEB 08 Audio System - Noise With Rear Defogger ON
07-62-07 JAN 08 Electrical - Parasitic Battery Draw Information
16-72-07 DEC 07 A/T - Learning Control Procedure
07-59-07 DEC 07 Lighting - Dew Formation Inside Exterior Lamps
17-13-07 OCT 07 Air Bag System - False DTC 26 Information
11-84-07 OCT 07 Fuel System - Cold Start Idle Fluctuation Explanation
09-47-07 AUG 07 Cooling System - Coolant Flushing Machines and Additives
15-125-07 AUG 07 Wheels/Tires - Wheel Lock Installation/Removal
07-60-07R APR 07 Ignition System - DTC's P0301/P0302/P0303/P0304
05-37-07 MAR 07 Wheels/Tires - Tire Rotation Pattern
15-120-07 MAR 07 Audio System - CD Player Information/Precautions
18-112-06 DEC 06 Service Manual Corrections
15-119-06 NOV 06 Audio System - Vibration from Front Door Speakers
09-45-06 NOV 06 Cooling System - Radiator Cap
02-100-06 OCT 06 Engine - Head Gasket Residue Removal Procedures
07-58-06 AUG 06 Lighting/Horns - Horn Production Changes
13-85-06 JUL 06 Body - Paint Codes/Cross References
11-73-05 FEB 05 Emissions - OBD I/M Test Scan Tool Protocol
01-156-03 NOV 03 M/T - Warranty Information Regarding Abusive Driving
Some look very minor, some more problematic. I looked up a Chevy Impala and it was longer than my arm on the ODI site.. I guess that water leaking problem is a big one to look out for.
Year : 2007
Make : SUBARU
Model : IMPREZA
Summary :
07 mustang pony pack
first off thank you for posting the recall list, i have a few things to mention to my technichian next oil change now lol..
I too have had some of the problems posted here, I also have 2007 v6.. Some of my problems include the noise when just idling with the clutch disengaged and it goes away when you put the clutch in. I mentioned it to ford and all they did was print this thing off the computer from ford saying that it is normal for the noise to be there and to only fix it if it becomes real loud or something like that.
I have the clunky shift from 1st to 2nd or when putting into reverse as well, annoying.
i never really thought too much of the noise when hitting speed bumps and what not, its been there for a while and i see other people are getting this as well..
As far as winter driving for you, i live in Ontario and i got my car in september and drove it in the winter with the standard tires which i think were summer.. I ended up putting like 250lbs of salt in the back, it did help and made me feel better in the snow but snow tires are real good idea for this car. Even with the salt it can be hard to go through some snow even if only a few inchs sometimes. Had same problem with my 95, put yokohama winters on and felt so much better. But as long as you are ok with doing really low shifts just the salt will be fine, spins out real easy when roads wet
listen for squeaks in the breaks too. I try not to be too hard on my car with the brakes and burn outs (partly cuz our cops are strict here for speeding and crap like that) but my brakes started to to make noise and when they checked the rear pads were worn and one was cracked. Of course my bumper to bumper just ran out like 3000km before that. Within the last couple weeks i've hear it again a few times, so whether this time its the front or they messed up on the back i dont know yet, havent had time to investigate
They do all right in the snow, but don't expect to be carving up a mountain road like you would in a Porsche, or even a Nissan. For that, you'd really be better off with something that has independent rear suspension.
Also, I have an '07 V6, and I like it, but if it were my first Ford, I would never buy another one again. The sound the transmission makes in neutral is very off-putting, and I've never been in a car that had even half as many interior rattles as this one. Most of the rattles were easily remedied, but you should know they're an issue, just in case that's a big problem for you. Mechanically though, I'd say this car is sound and fun to drive. It's just the little things that will drive you nuts.
Don't let the auto push you away from the orange one. My car is an auto and i would say it runs just as well as the stick cars. The trans is the same one that is in the GT so it can hold the little 210 HP V6 just fine. I have 8k on my 09 and I have taken it to the track and beat on it pretty good.
There are a few things to look out for with the stangs. But if you have the recall list just keep your eye out for those things. The water leak is a prominent problem, BUT NOT A PROBLEM FOR ALL. So be sure and check for it. Passenger side footwell there is a panel with a fuse box. It comes through the firewall and you will be able to see it there. Don't be scared of the auto. I drive one and am happy with it. Its stronger than the MT if you decide in the future to give it some more power. I hope you end up in our stang community. They really are great cars.
Hi, just a few questions. I have never owned a Ford, ever, first of all.. I will be going to a local Dealer who has an 07' V6 in Silver w/ 27k miles on it and it's a 5-speed too .
I was wondering if there is anything I should really look out for on these cars while test driving it besides all the normal stuff, I mean things specific to this car than might be a common issue, etc.
After looking at a bunch of different types of cars in that price range I think the V6 Mustang is one hell of a bargain for what you get. I can't wait to test drive the thing. They also have an AUTO in orange with 36k miles, but I don't think I want to stick out that much, or drive a sporty RWD car with an AUTO trans.
How is the reliability of these cars in general? If there are some issues, what are they? I have heard about the battery drain issue.. but that's about it so far. I definitely need to do some more research.
Thanks for any advice on this purchase..
