Fastest NA 4.0L V6 Mustang
Old 10-27-2009, 04:52 PM
  #21
up_yours_7
up_yours_7's Avatar
what would be the pricing for the heads and cams? I have been looking a lot at all motor before i go F/I.
up_yours_7 is offline
Old 10-27-2009, 09:05 PM
  #22
jimkaray
jimkaray's Avatar
Thanks for posting the info! I definitely like his sleeper set up and +1 to his minimalist approach. It shows that you don't need to throw lots of go fast parts at your car to make it run, just the right ones. A couple of observations. 1) Since the cams were designed for a centri set up that means the potential for even greater n/a power with cams ground for normal breathing is there, 2) the centri grind probably explains the big power jump on the bottle with only 750 psi. I'd have to say with a the bottle pressure up around 950 psi and a proper nitrous tune 11's are well within reach
jimkaray is offline
Old 10-27-2009, 09:14 PM
  #23
ranebowcyxx
BadAss 13-sec N/A 4.0L
ranebowcyxx's Avatar
Thanks for posting this Todd.
The cams are a pretty aggressive grind, they really need the 4.10s and the 3500 stall to work NA. Another note on the heads, I had them machined to accept Cobra springs which have allowed me to make power past 6500 rpm and when I had the Centri blower it helped to keep making power.
ranebowcyxx is offline
Old 10-27-2009, 09:59 PM
  #24
tx_zstang
tx_zstang's Avatar
A v6 with stock power is no fun .
For bolt-ons, those are great numbers (13's).
tx_zstang is offline
Old 10-29-2009, 07:50 AM
  #25
28HopUp
MF Administrator
28HopUp's Avatar
Tony, I love seeing the air under your tire - SWEET!
28HopUp is offline
Old 10-29-2009, 03:08 PM
  #26
Sancho805
Sancho805's Avatar
what did the head/cam work cost you?
Sancho805 is offline
Old 10-29-2009, 04:42 PM
  #27
pascal
S197 Section Modder-ator
pascal's Avatar
I agree, nice stance.
How 'bout air under the tires when braking/cornering?
SWEET too, I say.
pascal is offline
Old 10-29-2009, 06:44 PM
  #28
ranebowcyxx
The exact cost is hard to nail down, there was a lot of work done when the heads were done. I'm going to say the head work and cam grinds were in the 2800-3,000 range.
Old 10-29-2009, 06:53 PM
  #29
Avalanch3
Avalanch3's Avatar
Are you going to get a carbon/aluminum driveshaft? It is one piece and will shed around 30-40 pounds, and they claim to pick up some good RWHP from it.
But back on topic, killer times! Congratulations on the fastest N/A 4.0 time!
Avalanch3 is offline
Old 11-01-2009, 06:08 AM
  #30
firestang70
firestang70's Avatar
Congrats Tony! And to others the idle on this thing is wicked. It was alot of fun running around in that car even though its still yellow. j/k
firestang70 is offline
Quick Reply: Fastest NA 4.0L V6 Mustang
