Braided Brake Lines
Braided Brake Lines
I have been looking around for awhile now and it seems that no one makes braided brake lines for our 4.0's. The reason is is if you look at the flex line that comes off the caliper it connects directly into a solid 3-way block. This flex line may or may not be able to be removed. GT's obviously don't have this, ive already asked steeda and a few other manafacturers, but if a GT guy were to chime in and confirm, that would be great!
This whole project of adding GT-take offs has become a PITA. I know i could simply just swap them out, but the braided lines are a really great improvement.
Has anyone done this before or am i taking a shot in the dark. My next option is to go and get them custom made. Im really not looking for that bill!!!
I did a quick google search and came up with a few hits of interest. You'll want to research it more thoroughly but it looks to like the v6 w/ abs is the same part as the GT. It also looked like there is a non abs set available but it could be they didn't specify abs in the short description I read.
Do you have TCS? I don't think you can have one without the other - and it is easy to see if you have TCS because there is an "on - off" button on the center stack.
Also if you look in front of the air intake and you see a big box with several brake lines going in and out of the top, that is your ABS controller. Look just to the left in front of the CAI here, silver box with hard brake lines on top
I hav abs because when i turn the car on the symbol lights up but no tcs i dont have the upgraded computer and no tcs button above radio....
hopefully this wont effect the lines
i did find a company called stoptech that i will most likely order from.
I'd double check your ABS status and not rely on the fact that the light shows when you start it up because that my just be telling you the light is working and have nothing to do with the actual system test. Make sure you have the module in front of the air intake - my understanding was that ABS and TCS are only put in together and you don't have one without the other - but that could be wrong.
