Call your insurance agent and let him know what happened. Your car needs to be checked out by a mechanic. After that, I would get all the carpet inside replaced.
I too drove through high water a while back. (unavoidable, other wise I wouldn't have and it wasn't nearly as deep as what you went through) For a while a belt would squeak for a little bit right after being started. I ignored it for a while and it has now gone away.
Replica,
That some funny sh*t! The carwash vacuum? Man, I can just see the water running out the bottom, and it shorting out... I'd hope on the steed and fly before someone turns you in LOL
OP, if the car was submerged to axle height, your front wheel bearings are most likely shot.
That's the whining noise you're hearing.
Hopefully I'm wrong.
^^ Killing Wasps, Really? I use Carb cleaner. Works really, really fast. Doesn't give them a chance to attack you. I buy the cheap stuff a WalMart for $1.00, and I use it to kill bigs, weeds, clean intakes, strip paint, etc. Has lots of uses.
