Rear end clunk every time I step on the gas
Old 12-22-2009, 04:28 PM
bobs184
bobs184's Avatar
Default Rear end clunk every time I step on the gas
For the last two weeks, I've noticed a relatively subtle clunk from what appears to be the left rear of the car. It only happens when I let off the break and start to the touch the gas (so basically, between 0 and 5 mph). I don't hear this noise or anything abnormal while cruising, accelerating after the initial start off, or while breaking.
It's not overly noticable, but definitely is a new thing.
The car has 31,000 miles and is an automatic.
I'm not overly knowledgable on cars so I'm not really sure what this sound is. Thanks for any help
bobs184 is offline
Old 12-22-2009, 06:38 PM
6-Speed
6-Speed's Avatar
Are you sure the noise is not coming from the front of the car - like the front lower control arms?
6-Speed is offline
Old 12-22-2009, 06:44 PM
avengence
avengence's Avatar
Probably driveline slop. You might notice it more when its cold or something. Nothing to really worry about, they all do it to some degree. It could be something else though. Driveline slop can sound kind of like a thunk. Driveline slop comes from a mix of the trans, driveshaft and different gear tolerances not being too tight.
I know sometimes before I do gears on peoples cars if you drive slowly and go around 5 to 10mph and let off the gas and then hit it again it has like a slight clunk to it or something. Thats what im talking about. Usually after I do the gears it almost all goes away.
avengence is offline
Old 12-22-2009, 07:29 PM
Nuke
Nuke's Avatar
Check out http://iihs.net/fsm/?dir=76&viewfile...e%20System.pdf , page 205-00-6 for "knocks" and "clunks".
A certain amount of that can be considered normal. Our drivelines are pretty sloppy.
Nuke is offline
Old 12-23-2009, 10:56 AM
157dB
Cut & Paste Expert
157dB's Avatar
i HAD LOOSE DRIVESHAFT FLANGE BOLTS THAT Caused the very same thing
you are describing. Get under there and torque them to spec.
157dB is offline
Old 12-23-2009, 11:25 AM
bobs184
bobs184's Avatar
Thanks for everyone's help. I think the cold is definitely one reason for this, because i've been driving it alot in the 25-40 degree range and it hasn't been used to that. But it also seems like I hear a little more noise coming from the back end when driving over bumps or on a rough road, and I never really heard that before either.
bobs184 is offline
Old 12-23-2009, 02:18 PM
chrisverneuil19
chrisverneuil19's Avatar
Mine does the exact same thing. Its most noticble some days and its gone others. Ive been told its just slop in the drive train. I dont like it eiather but so far nothings wrong. Ive Got 34 and some change on her
chrisverneuil19 is offline
Old 12-24-2009, 10:10 AM
bobs184
bobs184's Avatar
Well I made an appointment with Ford on monday since I've still got two months of warranty left. I'll let you guys know what the say.
Today's a bit warmer out and it's still making lots of noise back there over some pretty small bumps on the roads.
bobs184 is offline
Old 01-25-2010, 08:28 AM
MustangFanatic44
Salad Farts
MustangFanatic44's Avatar
I just recently put on some aftermarket LCA with poly bushings, i hear the same thing, mines an manual so i hear it everytime the clutch engages and give it some gas, mainly downshifting though is when its worse.
I'm definetly going to check the driveshaft bolts to see if there loose or something, My LCA's are torqued down pretty tight though.
MustangFanatic44 is offline
Old 01-25-2010, 09:49 PM
bobs184
bobs184's Avatar
I can't really explain it, but the noise seems to come from the cold air intake believe it or not. It seems that the black plate that sits around the filter rattles occasionally. I hear it in the front, but somehow it equates to what I can describe as noise from the back. I adjusted this and made sure everything was tight and tied down and the noise stopped. Go figure.
On a brighter note, tomorrow I'm taking it in for a transmission flush and am excited about that. Also, I'm going to test drive a nice looking 07 GT black convertible with black rims. Looks fun!
bobs184 is offline
Quick Reply: Rear end clunk every time I step on the gas
