Check Charging System Warning!!! - Page 3 - MustangForums.com
Sponsored by:
Sponsored by:
Old 10-16-2010, 09:34 PM   #21
MustangGT13
hey guy's I'am havin that issue too but i know some basic car stuff. so i checked the battery it was dead changed it out for new one, then two weeks later happened again checked the alternator it was bad check battery it was fine just need to be recharged. Now almost 2 months later started to happened again.... please help if i can't fix it am goin to have to bring it to the dealership and have them fix it and I'am not under warranty anymore got 40k on my 07 GT. But i did noticed while i was drivin when i hit the brake pedal the battery level drop alil and alil more each time i hit the brake.
MustangGT13 is offline   Reply With Quote
Old 08-25-2013, 11:16 PM   #22
Jeff Ramsey
Does anyone Know what Relay Derf00 is refering to? I have the same problem described above I have gone thru two batterys and am on my 4th alternator in ten months. I would love to try changing the relay and see if things behave better.
Jeff Ramsey is offline   Reply With Quote
Old 07-22-2014, 11:47 AM   #23
koryvettore
koryvettore's Avatar
Default same problem
Quote:
Originally Posted by Derf00 View Post
There's a relay in the upper right hand side (drivers side under the dash) that maintains power when you turn the car off until you open a door. Sounds like relay is going bad. It controls all of the interior electronics. If it's going bad or is bad that would present the issues you are describing.
When you turn the car off and take the key out, before you open a door, listen very carefuly, you'll hear what sounds like two noisey small gears rotating, that's actually the relay. when you open the door it should stop after a second or two.
I have a new battery and alternator Could it still be the same problem
koryvettore is offline   Reply With Quote
Car died while driving... StalkerGT 5.0L (1979-1995) Mustang 13 09-25-2015 03:41 PM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 08:30 PM
Help! Metra 70-5521 AMP Harness Install cbird1177711 2005-2014 Mustangs 2 09-03-2015 09:43 PM
2003 mach stereo has low volume iamgobono General Tech 0 09-03-2015 01:37 PM
Best Place To Run Power Wire/Firewall '08 cbird1177711 2005-2014 Mustangs 3 09-02-2015 09:51 PM
05, 2005, 2007, 2009, car, charging, check, fix, ford, gt, light, mustang, system, tells, warning
