Rear Sway Bar Bushing
I personally used a 25TON press and a custom press bushing.
You can burn them and press them out.
Or cut the rubber flange on one side and press the rest out.
It just seems the word 'press' is being thrown around here a lot.
Maybe thats because thats bout what you need to get the little buggers out.
Just be sure and slide the links OFF of the sway bar before trying to remove them.
You can remove the inner steel sleeve and cut the remaining rubber portions
with a hacksaw blade thru the hole that the steel sleeves came out of.
Thanks again everyone. Got the rear sway bar done today,ended up using the socket trick and a vice,they came right out. And putting in the new poly bushing was pretty easy too. Next on the list is installing the front sway bar.
Thanks again
Thanks again
09-16-2015 07:53 PM
09-08-2015 11:50 AM
