07 v6 not starting after zex window switch install. - MustangForums.com
Sponsored by:
Sponsored by:
Old 02-11-2010, 06:04 PM   #1
fiveOH1985
fiveOH1985's Avatar
Default 07 v6 not starting after zex window switch install.
hey guys, im a long time member over on Allfordmustangs.com, but i figured id hop on here to ask you guys some S197 specific questions.
i installed a zex nitrous system on my 07 v6, and i was installing the window switch today. well, after i tapped into my tach wire, and reconnected my battery, i started the car, and noticed my window switch wasnt reading the right rpms, like it was jumping all over the place. so i figured it was a bad connection where i tapped into the tach wire. well, without thinking, i didnt disconnect my battery, and i unplugged the plug going to my coil, cleaned up the slice connection. then i went to plug the plug back in, and i must have had some wire sticking out of the connector, and i think it hit my copper purge lines, because there was a huge spark. and when i went to start my car, all it does is crank. its like its not getting any spark. it does the exact same thing as if you went and unplugged your coil. your engine will crank, but not start.
any ideas what i should check? will my tuner read any codes?
fiveOH1985 is offline   Reply With Quote
Old 02-11-2010, 07:02 PM   #2
Moderator
JimC's Avatar
Your tuner should read any codes. Hopefully you didn't fry the ECM with the spark.
What window switch did you put in - and if it isn't reading correctly make sure it is set up correctly. The 4.0 uses a waste spark so you have to set it for that fact.
JimC is offline   Reply With Quote
Old 02-11-2010, 07:11 PM   #3
fiveOH1985
fiveOH1985's Avatar
all my gauges still work and everything. it just wont turn over. just cranks and cranks and cranks. i will plug my tuner intonight after work. so if my ecu is fried, will my tuner even recognize it?
are there any fuses or relays i can check?
Old 02-11-2010, 07:34 PM   #4
volcomchester18
Check all your fuses, you probably blew a fuse. Check fuses underhood as well as cabin. If after that it doesnt start check for spark, and so on. If you have a multimeter makes it much easier, since you dont have to pull them and visually look at them.
volcomchester18 is offline   Reply With Quote
Old 02-11-2010, 07:45 PM   #5
fiveOH1985
fiveOH1985's Avatar
Quote:
ok, and to double check the in cabin fuse box is behind the passenger kick panel? and aslo, i do have a multimeter, so how do i use it to check the fuses?
Old 02-11-2010, 08:45 PM   #6
Buckshot Barry
Buckshot Barry's Avatar
Put the meter in "Ohms" test. Take the 2 probes and touch them together. You should get close to "0" ohms. Then you can pull each fuse and go across it with the probes. Good fuses should read close to "0" ohms. Open fuses (bad) should read close to infinity.
Buckshot Barry is offline   Reply With Quote
Old 02-11-2010, 08:50 PM   #7
Jebmustangv6
Jebmustangv6's Avatar
Quote:
um why not turn on the key and set the volt ohm meter to volts DC setting. Then ground the black or negative lead and use the red lead to touch both sides of each fuse then you know for sure your getting voltage across the fuse. JMHO
Jeff
Jebmustangv6 is offline   Reply With Quote
Old 02-11-2010, 09:05 PM   #8
fiveOH1985
fiveOH1985's Avatar
Quote:
Jeff
so turn the ccar on, ground black, and then just touch the top of the fuses?
Old 02-11-2010, 09:30 PM   #9
Moderator
JimC's Avatar
fiveOH1985 - where in Michigan are you located, I just remember you said that Lidio did your tuning so figure you must be somewhere in SE Michigan
Old 02-11-2010, 10:16 PM   #10
fiveOH1985
fiveOH1985's Avatar
Quote:
yup, im in canton. 20 minutes west of detroit. where are you at?
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 07:47 AM
Window Motor(new) Issue: Opposite Direction HorsePower99 4.6L (1996-2004 Modular) Mustang 1 08-26-2015 11:29 PM
Window Motor(new) Issue: Opposite Direction HorsePower99 General Tech 2 08-26-2015 08:32 PM
AC Help! (please!) 2000 Mustang GT MXBT187 General Tech 2 08-20-2015 02:36 AM
2002 3.8 electric problem daytooday General Tech 0 08-16-2015 08:22 AM
07, 38, 40, 99, install, installing, mustang, sale, spark, switch, system, tachometer, tc, v6, waste, window, zex
