V6 X-Charger or Vortech HO? Advantage between gear driven and twin screw?
Old 12-26-2012, 08:25 PM
  #81
Moderator
JimC's Avatar
On the Xcharger meth will strip the coating off the rotors. The only way to spray it is before the rotors. On a centrufigal SC you won't have that problem and get the benefit of meth's cooling as well as octane boost. The only issue is that you have to worry about running out of fluid, or the fluid not coming on when needed - the intercooler doesn't have that problem.
And this is what the rotors on the Xcharger look like with meth. I took these pictures when I upgraded a friend's car to the Xtreme.
JimC is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: V6 X-Charger or Vortech HO? Advantage between gear driven and twin screw?
