reconnecting battery...+ first or second?
Quick question for you guys. Had to disconnect my battery and now I'm going to reconnect it.
Do I attached the positive (+) cable FIRST, then the negative?
Or do I do the negative (-) cable first, then the positive?
Thanks guys. Couldn't find this info in the owner's manual.
I always reconnect the + cable first then if my wrench slips to the chassis someplace I do not get a short circuit. Reconnect the - cable last and if that accidentally shorts to the frame of the car with the wrench slipping, nothing will happen.
Wrench could touch chassis and short battery causing a real bad acid explosion...
Positive first, negitive last when re-connecting battery.
Oppisite when removing battery.
And no jewelry such as rings, please.
They get awful hot when they short the battery terminals...
Wrong.
The other method will land you trouble
