Just when I thought...
Old 10-19-2010, 10:15 PM
AlloySixxer
AlloySixxer's Avatar
Default Just when I thought...
Just when I thought I was finally good to go with the supercharger, another problem arises...
So, I finally got the wideband A/F gauge installed and I'm reading 21.9 while at idle/cruising and it only goes down to 17ish when I step on it. The guy at the shop (a good mustang speed shop) re-calibrated it 3 times and still got the same numbers. So basically, it's reading that I'm lean as s**t. I talked to Dave who's trying to get into contact with Doug and it could be two things.
1. Doug's rather rich tune is somehow messed up and super lean.
2. The A/F gauge sensor came toasted out of the box and is reading wrong.
The car seems to run fine to me and the bung weld is in a good place, so I really don't know what else to think.
AlloySixxer is offline
Old 10-20-2010, 06:32 AM
2005Redfire6
2005Redfire6's Avatar
.....get it dyno tuned.
2005Redfire6 is offline
Old 10-20-2010, 07:29 AM
EVILHORSE
EVILHORSE's Avatar
what kind of wideband do you have?
EVILHORSE is offline
Old 10-20-2010, 10:03 AM
AlloySixxer
Innovate Motorsports
Old 10-20-2010, 10:43 AM
howarmat
s197 Junkie
howarmat's Avatar
only reading you should care about is WOT. the other readings (idle) arent accurate
howarmat is offline
Old 10-20-2010, 10:46 AM
EVILHORSE
EVILHORSE's Avatar
innovate is one of the best widebands out ,this is the first time I heard of anyone having issues with thier units .I would definetly check the bung location and angle again ,also check the weld on the bung.
Old 10-20-2010, 10:48 AM
EVILHORSE
EVILHORSE's Avatar
Thumbs up
very true +1
Old 10-20-2010, 11:29 AM
Moderator
JimC's Avatar
Where do you have the sensor bung located? It needs to be between the cats and the engine to get an accurate reading.
JimC is offline
Old 10-20-2010, 03:19 PM
AlloySixxer
Hmm, I believe it's behind the driver side cat, so it's not between the cat and the engine. The shop said this was a good place. Dang.
Old 10-25-2010, 11:24 AM
2005Redfire6
Did you get this issue figured out?
Quick Reply: Just when I thought...
