pypes x pipe vs ford racing x pipe
Old 02-08-2011, 04:47 PM
Nice Pony
Nice Pony's Avatar
The Ford Racing parts fit perfectly. I have installed a few of the Ford Racing kits on a few cars without issues. If you do a little research you will find that the Pypes system generally have fitment issues especially where the mid pipe goes over the axle and even worse on lowered cars. Pypes headers however seem to fit perfectly but again are of little to no use on a N/A car. As stated buy others duals is not going to make much if any power on a N/A engine but is required on a F/I engine. With F/I the H will make a tad better low end power while the X will make just a bit more top end power. But we aren't talking about huge amount of difference here. H will sound a little lower the X which will sound a bit more European or raspy. I run the Ford Racing which comes with an X pipe with dual GTA's and get a lot of complements on the sound. Another nice feature of the Ford Racing kit is they do not drone at all.
Nice Pony is offline
Old 02-09-2011, 06:00 AM
Norm Peterson
Norm Peterson's Avatar
Originally Posted by MustangFirstCar
An H pipe is true duals. X or H, there are really only 1 difference. The H pipe is a bit louder and deeper and the X pipe is raspier. Some think that X pipes are better flowing, but I have heard people say the same about H pipes too. None of it matters on our little 4.0s though; they don't make enough power (even supercharged) for the difference between an X or H to be noticed.
Ummm . . . traditional "true duals" have no crossover between the two banks at all. Loudest and probably the harshest sounding.
What's called an "H-pipe" these days is what used to be called a crossover (back when there weren't any "X-pipes"). It's a little quieter and more mellow than true duals. H-pipes flow better than true duals at least when you've got mufflers behind the H because you do have some flow sharing.
An X-pipe does a better job of making the exhaust system share flow than an H does because there are no 90° turns for the exhaust gas to have to make, just a couple of gentle bends. This also kills off the low frequency rumble (which is a function of the "normal V8" firing order), so the "tone" moves up in pitch and gets "smoother" or "snarlier" (and slightly quieter). There is a little top end power to be had with this arrangement, since the closer the flows through your two mufflers get to being equal all the time, the overall backpressure drops a little.
Norm
Norm Peterson is offline
JonnyBlazeGT
11-03-2015 01:10 AM
squishbang
Suspension
11-02-2015 03:42 PM
squishbang
09-07-2015 07:57 PM
Urambo Tauro
09-07-2015 12:47 PM
mustangfan305
08-07-2015 11:09 AM
Quick Reply: pypes x pipe vs ford racing x pipe
