rpm problem
Old 02-15-2011, 06:06 PM
dbirdrm
dbirdrm's Avatar
Default rpm problem
my friend wants to know if rpm problem can be caused by his new exhaust i said it cant
dbirdrm is offline
Old 02-15-2011, 07:27 PM
JCON
JCON's Avatar
The slow acceleration is unfortunately cause by the v6 in your engine
fluttering idle at start up is normal.
fluttering once at operating temp is a little odd and the tone of your engine changing but your rpms not is cause for concern. Since you're manual, you control your gear. Maybe your having an issue with the dreaded tach motor failure. I believe there is a TSB for it on these forums.
JCON is offline
Old 02-15-2011, 07:31 PM
dbirdrm
dbirdrm's Avatar
[QUOTE=JCON;7420195]The slow acceleration is unfortunately cause by the v6 in your engine
iyea tru that
dbirdrm is offline
Old 02-15-2011, 10:51 PM
JCON
JCON's Avatar
use a GPS and check to see if your speed on it and your speedometer are rising at the same rate. My guess is you may have dead motors in your guages
JCON is offline
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Omgitsa88Stang
10-05-2015 07:33 AM
musnicki
09-23-2015 07:11 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: rpm problem
