HELP!!! IM an idiot =(
Old 04-10-2011, 06:52 PM
whitethunder09
whitethunder09's Avatar
Default HELP!!! IM an idiot =(
I need to know how to disconnect my battery on my mustang 09 v6. I bought a used diablo predator today and the guy didnt restore his mustang to the factory settings and I put on a tune and it said it wouldnt work so now my car wont start and the autozone guy told me to disconnect my battery but the only problem is idk how to disconnect it? I have had several instructions but i still have no idea. please help and explain in detail. guess I'm not as smart as i thought I was.
whitethunder09 is offline
Old 04-10-2011, 07:01 PM
MadStang40
MadStang40's Avatar
.......disconnect the leads to both terminals on top of the battery? Make sure the car is off and use a wrench to loosen up the connections. If it's hard removing the connections, use a screwdriver in tandem and slowly pry off the connections... is this what you were looking for?
MadStang40 is offline
Old 04-10-2011, 07:04 PM
whitethunder09
How do you disconnect the leads though? idk what those are lol
Old 04-10-2011, 07:08 PM
MadStang40
MadStang40's Avatar
..... the two cables running to the top of the battery have metal connectors. Remove these.
http://www.google.com/imgres?imgurl=...w=1024&bih=653
Old 04-10-2011, 07:12 PM
MustangFTW
Guest
Posts: n/a
http://www.dummies.com/how-to/conten...r-battery.html
google is your friend.
Old 04-10-2011, 07:31 PM
aaquib1992
aaquib1992's Avatar
yeah what madstang said, make sure to get the one under the red cap and then let the car just sit without the batt for about 20 minutes.
BUUT, disconnecting the batt will NOT reset the tune buddy, on my car it didn't (took the batt out last week for some work) so I think you have to reload the stock tune from the tuner you have.
aaquib1992 is offline
Old 04-10-2011, 08:04 PM
whitethunder09
DANGITT okay well thank you for tellling me. How do I get the factory tune back on my car with the tuner?? I tried to restore the "original backup" and it said that it couldnt work because it didnt save or something like that. am I screwed??? Lol
Old 04-10-2011, 08:21 PM
obxdude018
obxdude018's Avatar
If your car is left with a tune on it and you don't have the original tuner that stock tune was put on, then you need to take it to the ford dealer and get a new stock tune put on your car
obxdude018 is offline
Old 04-10-2011, 08:29 PM
Nuke
Nuke's Avatar
Buying used tuners can certainly be an adventure.
Contact Diablo tomorrow and see if they can help. I don't think disconnecting the battery will help but it's worth a try.
Nuke is offline
Old 04-10-2011, 08:32 PM
whitethunder09
okay well if I got the guy to set his car back to stock could I put the tuner on my car to make it work or do i have to take it to ford no matter what??
Quick Reply: HELP!!! IM an idiot =(
