A MUST SEE! RPM Roll Bars on "Two Guys Garage" 5/28th! NHRA Legal Bolt in Cages:
Old 06-09-2011, 12:31 AM
beaustang
beaustang's Avatar
Do you need a test mule for the vert? Dibbs if you do!
beaustang is offline
Old 07-19-2012, 11:37 AM
Gidyupp
Gidyupp's Avatar
Originally Posted by John@TrackspecMotorsports
Thanks for the compliment!
[*]The Maximum Motorsports cage is not designed with the use of sandwich plates on the main hoop bolt down area. This is the area of the cage that takes all of the stress during a roll over and must be sandwiched for strength. [*]The RPM Cage comes with sandwich plates for all mounting points of the cage, meeting and exceeding NHRA dimensions.
This seems a bit misleading to me. The MM bar lands on the B-Pillar support using a stout looking bracket.
No backup plate possible or required.
Does your bar land on the sheet metal rear floor like the Autopower cage? (note the ends of the main hoop poking through the floor)
Not saying that the bar failure in the photo was due to the design. Installation may have been a factor, but I have to believe that the bulkhead is stronger than the floor sheet metal, backing plates or not.
Not knocking your design (never seen it) just looking for clarification as I'm in the market for a bar and the MM was on the top of the list.
Attached Thumbnails A MUST SEE! RPM Roll Bars on "Two Guys Garage" 5/28th! NHRA Legal Bolt in Cages:-bar.jpg   A MUST SEE! RPM Roll Bars on "Two Guys Garage" 5/28th! NHRA Legal Bolt in Cages:-fail.jpg
Gidyupp is offline
ShaneB26154
35
03-04-2021 04:05 AM
msavoia23
12
07-07-2018 12:08 PM
drfister
05-03-2018 10:38 PM
duffman668
08-26-2015 04:46 PM
cedarmn
08-20-2015 03:14 PM
Quick Reply: A MUST SEE! RPM Roll Bars on "Two Guys Garage" 5/28th! NHRA Legal Bolt in Cages:
