A MUST SEE! RPM Roll Bars on "Two Guys Garage" 5/28th! NHRA Legal Bolt in Cages:
Hey guys,
Just wanted to let you know coming up this saturday may 28th, "Two guys garage" on the speed channel will be doing an install and product feature on the 100% NHRA Legal bolt in roll cage manufactured by RPM Roll Bars available thru Trackspec Motorsports
You dont pass tech, WE BUY THE CAGE BACK!!!
What makes RPM Roll Bars Different?
•NHRA LEGAL S197 Mustang 10.0-11.49 bolt in roll cage!
•NHRA LEGAL Door swing out. Door swing out is completely removable for street driving and easily installs in seconds at the track!
•NHRA LEGAL Bolt in shoulder seat belt mounts
•Mild Steel or Chromoly Mandrel Bent Tubing meets and exceeds NHRA regulations.
•CAD engineered and precision welded robotically
•Each roll bar contains a manufactured chassis tag including date and serial number to prove authenticity and certification.
•Completely removable and 100% welded. This bar comes ready to bolt in, fully coated!. When reselling the vehicle, removal is simple and you can even resell the roll bar!
•5 Point roll bar includes driver side swing out door bar only. Add Passenger door bar in options!
•Factory seat remains fully adjustable. Custom designed for each application, these Roll Bars allow for complete seat adjustment front to rear!
•Custom engineered to aesthetically follow factory interior lines and flow.
•Full detailed instructions with pictures, and all hardware included. Install your custom built, fully coated, NHRA Roll Bar in weekend with simple handtools!
Roll Bar Options
•6 Point option: Add a passenger side swing out door bar.
•8 Point option: If you break the 9.99 mark, an 8 point upgrade kit is available to weld onto the existing cage.
•Autocross/Roadracing: Add Cross-bar for additional stiffening in roadracing and autocross applications
Coating Options All cages come 100% coated! Choose from standard colors listed at no additional charge!
•Red
•Gloss Black
•Flat Black
•White
•Blue
Basically any color that doesnt require custom mixing or paint codes.
Custom Paint Match: For a custom look, choose the "Custom Paint Match" option. Thats right, we can get your S197 Mustang Roll Cage to match perfectly to the exterior of your car or any color you want! All we need is your paint code. Select "Custom Paint Match" option to color match your Roll Cage to your S197 Mustang or any color imaginable! Looking for Sonic Blue? Torch Red? Or how about a Leguna Seca blue Roll bar? All we need is a paint code! After your order is placed, you will be contacted by an associate at Trackspec Motorsports to get your custom S197 Mustang Roll cage paint match code!
Hydro-Dipped Coatings: Take your S197 Mustang NHRA legal Roll cage to the next level with our custom Hydro Dipped Option! Our most popular Hydro Dip option is the Carbon Fiber look. See attached pictures for examples.
•Standard Carbon (shown in photo)
•Blue Carbon
•Green Carbon
•Orange Carbon
Hundreds of other pattern available! Skulls, Reaper, etc.
Custom Paint Match with Hydro Dip: If you are looking for that one off S197 mustang Roll Cage or just plain want to have a custom look that no one else in the world has, try the Custom Paint Match Option with Hydro Dip overlay! We will spray your Mustang Roll Cage the base coat color match of your choice and then perform a hydro dip overlay ontop of it! Only a few have selected these 2 options on their roll cages but the results were absolutely stunning! How about a Boss Yellow paint match with Carbon Fiber Overlay? Set your S197 Mustang Roll cage apart from the rest with a unique color/dip combo
Let us know if you have any questions on the cage.
We are RPM's Largest Roll Cage dealer and have sold cages world wide!
John@trackspecmotorsports.com
Roll Bar Options
•Red
•Gloss Black
•Flat Black
•White
•Blue
•Blue Carbon
•Green Carbon
•Orange Carbon
RPM Roll Cage
These are in fact, some of the best engineered, highest quality Bolt in roll cages on the market. The MM cage is a nice peice, but there are some key differences that make the RPM cage a step above the rest.
Some facts to note:
- The Maximum Motorsports cage IS NOT NHRA LEGAL out of the box. NHRA rules dictate that the rear down bars from the main hoop must be welded, not bolted. The MM instructions state that their cage must be first bolted and fitted, then taken to a professional welder to have the rear down bars permanantly welded to the main hoop.
- All RPM Roll bars come 100% welded and are a true bolt in installation. NO WELDING REQUIRED!
- The Maximum Motorsports cage DOES NOT have an NHRA CERTIFICATION TAG on the cage. Tracks are getting especially strict and most Techs look for the chassis tag to prove NHRA authenticity.
- All RPM Roll cages each come with their own individual chassis tags with date of build and serial number, proving NHRA CERTIFICATION to the tech inspectors. RPM Roll bars is an NHRA certified chassis manufacturer. YOU DON'T PASS TECH, WE BUY THE BAR BACK GUARANTEE!
- The Maximum Motorsports cage is not designed with the use of sandwich plates on the main hoop bolt down area. This is the area of the cage that takes all of the stress during a roll over and must be sandwiched for strength.
- The RPM Cage comes with sandwich plates for all mounting points of the cage, meeting and exceeding NHRA dimensions.
- The Maximum Motorsports cage comes BARE and UNCOATED. You need to fit the cage and remove it to be welded then coated. Some spray can it or send it off to be powder coated. Cost cost cost.
- The RPM Roll cage comes fully coated in standard powder coating for mild steel cages or base coat/instrustrial strength cleared for Chomoly Cages. But the coating options don't stop there. All cages can be custom color paint matched or hydro dipped for that carbon fiber, skulls, ****** wire, reaper etc look. The coating options are unlimited!
- The Maximum Motorsports S197 Cage doesnt list a swing out door bar option for S197's, just standard fixed door bars.
- The RPM Cage comes with swing out door bars that are 100% NHRA legal and completely removable in seconds. Just remove the pin and lower bolt and out it goes. To protect the paint, RPM has added carbon fiber look inserts in the swing out area. This prevents the paint to paint contact that causes chipping.
- The Maximum Motorsports cage has a rear shoulder bar attachment that is not recessed to allow for full factory seat movement, front to back.
- The RPM cage has a specially designed rear shoulder bar that allows full front to back seat motion.
- The Maximum Motorsports cage has a very involved installation process that has several steps to complete. From removing the interior, fitting the cage, removing the cage, having a professional welder weld the rear down bars, getting the cage coated, and then reinstalling.
- The RPM cage is a true bolt in, 100% welded, 100% coated, ready to install roll cage that can be installed at 8am and ready to hit the strip that evening. Normal installation times vary from 6-8 hours total, depending on how familiar you are with removing the seats and rear panels.
The maximum motorsports cage is a nice piece, but understand the important differences between the 2 cages when comparing costs. If you add up all the time and money for install, welding, and coating for other cages, the RPM cage is an excellent value for a cage of the utmost in quality, precision fit and finish built by an NHRA certified chassis manufacturer.
We love Maximum Motorsports parts and we run their entire rear suspension set up on our roadrace fox, their parts are top notch so we are not at all knocking their products, just simply pointing out the key differences between the cages. We sell maximum motorsports suspension too!
A little about RPM Roll Bars:
With over 40 years combined of race car engineering and building, RPM Rollbars has been producing record-setting, champion race cars in pro street, super street, super gas, comp eliminator, pro mod, alcohol funny car, and alcohol dragster. The state of the art facility located in Newberg, OR contains only the latest technology in fully automated robotic welding equipment to bring their professional race customers only the highest level of quality and safety that a leading edge chassis manufacturer can bring.
Please let me know if you have any questions on the cage, we'd love to help you out with your needs! Look for a group buy on these coming this week for special pricing
RPM Roll Bars- Top quality NHRA legal Roll Cages: 99-2012 Mustang
Pics of the Carbon Fiber look insert at friction points of the door swing outs and also a couple other customer cages in the 2010 Camaro- Carbon Fiber hydro dip with a blue base coat. Quality and attention to detail on these cages are impeccable. Thanks for looking guys, appreciate the questions on these!
Working on getting vert pics soon.
The link to the GROUP BUY with some great pricing!!
Trackspec Motorsports Sponsoring: RPM Roll Bars Group Buy!!
With the Group buy pricing, these top quality cages become very competitive with the MM cage! Remember this come ready to bolt in, fully coated and welded with NHRA cert tag built by and an NHRA certified chassis fab shop...RPM Roll bars!
