Removing valve covers... how to?
Old 06-09-2011, 08:57 PM
numb1zero
numb1zero's Avatar
Default Removing valve covers... how to?
Hey guys, ive looked all around for a quick how-to on removing the 4.0 v6's valve covers with no luck
Does anyone know of a write up or feel like writing up a little guide for me?
I just want to paint them with some high temp engine paint.
Thanks in advance!
-Adam
numb1zero is offline
Old 06-10-2011, 05:58 AM
2005Redfire6
2005Redfire6's Avatar
There isn't much to it, you should be able to see the bolts that hold the valve covers down, when you find them all from there you just remove the hoses/brackets that are in the way on the valve covers or around them!
2005Redfire6 is offline
Old 06-10-2011, 10:22 AM
MustangFirstCar
MustangFirstCar's Avatar
Yes, it sounds easy, but I agree, a writeup would be really nice.
MustangFirstCar is offline
Old 06-10-2011, 10:26 AM
bakerjd
bakerjd's Avatar
Grab yourself a Haynes manual at the local Autozone and go to work. I don't know about the 6 engines but I know during the reinstall on the 8's you need a torque wrench capable of at least 88lbs force. Make sure you read through the Manual thoroughly before you attempt anything. Good luck and make sure you post pics!
bakerjd is offline
Old 06-10-2011, 03:19 PM
ABQstang89
ABQstang89's Avatar
It's pretty easy guys. You have to take off the coil pack which is a few bolts. It think there is 8 bolts per cover, you will need a deep socket (8mm i think). The egr stuff just has clips to remove them. That's all there is too it. You will have to fight the wiring a little but its not that bad.
ABQstang89 is offline
Old 06-11-2011, 06:58 AM
2005Redfire6
Also on the passenger side there are a few hoses with a bracket on the back of the valve cover, thats the only thing that really sticks out in my memory about taking them off it was a PITA.
Old 06-12-2011, 12:21 PM
numb1zero
numb1zero's Avatar
This makes me nervous, I don't own a torque wrench and I don't want to damage anything doing this wrong...
Old 06-12-2011, 12:24 PM
2005Redfire6
I've never used a torque wrech....
Old 06-13-2011, 08:31 PM
numb1zero
numb1zero's Avatar
Oh well then I oughta give it a shot any reccomendations on paint brands or types?
Old 06-13-2011, 09:19 PM
tx_zstang
tx_zstang's Avatar
high-heat paint. Get them good and clean. dont get gas on them after painted.
tx_zstang is offline
Quick Reply: Removing valve covers... how to?
