Auto Trans Fluid, the good ol' days and a Hot key
Old 07-04-2011, 05:26 PM
MoneyShot
MoneyShot's Avatar
Default Auto Trans Fluid, the good ol' days and a Hot key
In the good ol' days all you had to do was unbolt about 15 bolts, drain the fluid, install a new gasket and filter and refill with the dip stick. Now-a-days you don't even have a dip stick, special tool are required, and a once simple task requires many hours or an ASE certified mechanic.
Anyone tried this? There is a drain plug which is nice but you also have to fill through a little plug. ??? The pan is also stamped that the gasket is reusable. anyone reuse it?
Anyone have Ford do it? How much?
2nd unrelated question: Anyone have their key get hot after driving a while. My key and ignition get really hot sometimes. I don't think that its a mustang thing cause my eclipse used to do it too. Just curious
MoneyShot is offline
Old 07-04-2011, 09:02 PM
MustangMan1718
MustangMan1718's Avatar
For the transmission, it is recommended to actually not drop the pan. Instead, our shop hooks the transmission machine up to the cooler lines. This is a ~98+% fluid exchange while dropping the pan gets about ~60%. It gets it all out of the filter and torque converter this way too. As for price, around here it can be found for $100-150 depending upon discounts and labor costs.
MustangMan1718 is offline
Old 07-04-2011, 09:26 PM
808muscle
808muscle's Avatar
There is a DIY on the auto fluid change. It's a good read. I did mine last October. I dropped the pan, swapped the filter and attempted to refill. It's really a slippery mess and in the end could not get it all in as it kept pouring out. So I measured how much I drained accounting for what spilled on me and the driveway and then pumped that in. Your car must be perfectly level to get a accurate reading. My car was not.
This year I hope to be better at it.....lol. I change mine every year cause I race it a lot.
808muscle is offline
Old 07-05-2011, 05:21 PM
MoneyShot
MoneyShot's Avatar
cool. good to know guys. do our pans have a shavings magnet in them? seems like not dropping the pan would miss the magnet and anything in the filter. I don't see how the 60%/98% could be true, that seems low/high but I don't work at a shop.
Any word on the keys?
djbigskrilla
09-20-2022 01:04 AM
Lee1911
09-01-2015 02:12 PM
kdryan
08-21-2015 04:01 PM
Stilz
08-19-2015 06:17 AM
Stilz
08-18-2015 09:40 AM
Quick Reply: Auto Trans Fluid, the good ol' days and a Hot key
