2005 Power Driver Seat
Old 07-31-2011, 04:35 PM
vfd241
vfd241's Avatar
Default 2005 Power Driver Seat
Having problems with the driver side power seat - don't know if it's the switch or motor....will slide forward but not back and will not tilt up or back. The motor does make a noise when trying to tilt down but sounds like it is jammed...no noise at all trying to tilt up. After playing with the switch for awhile the motor seemed to get hot...don't know if this is normal or if the motor is bound up. If I need to replace the motor, how difficult of a job is it? I can see the 2 frame bolts in front but dont know what type of tool is used for the rear bolts. Can someone please advise?? Also should I replace both motor and switch together. I hope this is not a bad repair.
vfd241 is offline
Old 07-31-2011, 05:00 PM
Nuke
Nuke's Avatar
This may be of some help: http://iihs.net/fsm/?dir=1
Nuke is offline
Old 07-31-2011, 05:33 PM
pascal
S197 Section Modder-ator
pascal's Avatar
LOL, Nuke. Paypal ain't gonna help!
OP, I haven't had one of those apart yet but most likely, the gears (made out of plastic) are as toothless as a redneck jawline by now...
The shaft is spinning but the gears won't engage properly.
If the motor is binding, then you have another issue but you won't know until you have the seat out.
If you hear the motor, then you know that the switch is good since power is still being delivered.
The back part of the seat frame has a plastic cover that needs to be pulled back (not lifted up) in order to get to the bolts...
So get those out and undo those bolts first, then undo the front ones.
It might be a pain in the butt since your track doesn't move all the way back anymore but you should be able to do it.
Good luck.
pascal is offline
Old 07-31-2011, 06:36 PM
Nuke
Nuke's Avatar
Originally Posted by pascal
LOL, Nuke. Paypal ain't gonna help!...
You have to get past the first page, pascal. Stay with me here, bud...
This section http://iihs.net/fsm/?dir=449 should provide some additional insight.
Nuke is offline
Old 07-31-2011, 07:07 PM
pascal
pascal's Avatar
What?!?! Are you gonna make us work hard on late Sundays??
More than one click is overtime around here.
Oh, and I'm watching Ron White, lol.
pascal is offline
bjdutch2005
03-24-2017 03:38 AM
bconboy
09-21-2015 12:52 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: 2005 Power Driver Seat
