Factory Satellite Radio in Aftermarket Head Unit
Hey guys,
I have a double din pioneer avh-3300 in my mustang and was wondering if there was anyway to attach the factory satellite radio to the head unit. Anyone ever done this? Thanks
No, stick a fork in it, as it's done, unless you get another similar factory head-unit. It's a separate module in the trunk that connects to the factory head-unit using the can-bus, I don't believe this follows any standard, so there is no interface adapter made for it. As such, once the factory head-unit is out, it's a paper-weight. You could however re-use the antenna, with the proper extension if you got an add-on that could use it.
From the A/V section, man.
09-24-2015 09:18 PM
