2012 mustang axle??
Old 01-08-2012, 09:06 PM
up_yours_7
up_yours_7's Avatar
Default 2012 mustang axle??
Will it fit my 05 v6? It has less than 9k miles on it and has the 2.73 gearing??
up_yours_7 is offline
Old 01-09-2012, 05:59 AM
Moderator
JimC's Avatar
It mounts exactly the same so yes, it will fit. The pinion flange may even fit, last one I arranged to get shipped to someone was from a 2011 and he didn't have to change the pinion flange to fit his 2007 V6 driveshaft.
JimC is offline
Old 01-09-2012, 12:00 PM
GrayPony
GrayPony's Avatar
You current gears are 3:31 why would you want 2:73s?
GrayPony is offline
Old 01-09-2012, 12:17 PM
defiance
defiance's Avatar
Im thinking he meant 3:73 ? 2:73 does not make any sense.....
defiance is offline
Old 01-09-2012, 12:46 PM
up_yours_7
up_yours_7's Avatar
There is a guy on classifieds here in my town selling it for $50 and he says it's 2.73
Old 01-09-2012, 01:28 PM
Derf00
Gentleman's Relish
Derf00's Avatar
273 is probably what you have right now. I forget the year the V6 auto went to 331.
For 2011 and 2012 I believe 331 was the lowest gear the factory had...?
Could be wrong though...?
Derf00 is offline
Old 01-09-2012, 03:09 PM
obxdude018
obxdude018's Avatar
Ford released 2 stock rear ends with the '12, 2.73 or 3.31, and those are the 8.8 rear ends so you get a much stronger rear end as well, thoroughly inspect that rear-end, because that person doesn't know he could probably get 400-500 out of it by selling to someone who has an older s197 so there is either something wrong with it or he is just clueless.
obxdude018 is offline
Old 01-09-2012, 07:26 PM
up_yours_7
up_yours_7's Avatar
im going to get it now he said it is out of a 2012 v6 he swapped in a shelby rear end.
Old 01-09-2012, 07:30 PM
up_yours_7
up_yours_7's Avatar
so looking at it they made this axle for econmy so would it be a bad idea to drop gears like that since its not really upgrading at all?
Old 01-09-2012, 08:00 PM
unitedwestang
unitedwestang's Avatar
Even just for the axle $50 isn't bad. You can just buy gears for it and have them installed for about the same or less as buying a used axle with gears.
unitedwestang is offline
Quick Reply: 2012 mustang axle??
