Manual Tranny fluid recommendation? (other than ATF)
Old 02-11-2012, 08:04 PM
hueyhy
hueyhy's Avatar
Default Manual Tranny fluid recommendation? (other than ATF)
I changed my oil to Mercon ATF, but it is a disatster. so hard to shift into gears.
I just filled until it spills out. then I stopped and waited for minutes, and then put the fill plug in.
ALso get my short shifter. But I don't think that's the problem of the problem.
my post describing problem is here:
https://mustangforums.com/forum/gene...tallation.html
In short, when engine is ON, it's hard to get in gears. When it is oFF, it's smooth. seems it's the synchros. and some say it might becuase of the fluid. (don't really have serious sync problem before)
Anyone has some other recommendations about MTF on our T5 tranny? Don't really feel comfortable with ATF in my tranny.(and not sure that's what caused my synchs problem?)
hueyhy is offline
Old 02-11-2012, 08:36 PM
up_yours_7
up_yours_7's Avatar
Royal purple synchromax I have had it in since I replaced my clutch and love it.
up_yours_7 is offline
Old 02-11-2012, 08:39 PM
hueyhy
hueyhy's Avatar
see. but also some people say our T5 is different that we can't use MTF in them. really confused on what oil should use.
BTW, could my problem be a bad clutch? (not fully released?)
any idea to diagnose it?
just got the car, it's high mileage, so have no idea if the clutch is good or bad.
it is definitely not slippery.
but i can feel the clutch's engage point is very low. Is there any way to adjust it?
hueyhy is offline
Old 02-11-2012, 09:23 PM
up_yours_7
up_yours_7's Avatar
It's hydraulic so you can only bleed the line which I did when I replaced my clutch and it's a pain. Check the fluid level
Old 02-11-2012, 09:31 PM
hueyhy
hueyhy's Avatar
did the bleed help? I just want a higher engage point. (some other people also doubt that my problem is caused by not fully disengaged clutch)
if the bleed can like "adjust" the clutch pedal, and can help the clutch fully seperate, that should help
did the bleed on my civic si when I changed my clutch. I will see how difficult it is.
hate that there's no other way to adjust the clutch pedal. on my civic si, there's some bolt I can adjust.
hueyhy is offline
Old 02-11-2012, 09:35 PM
up_yours_7
up_yours_7's Avatar
Not really help much didn't change it at all putting a new clutch in changed the pedal engage points and stuff a little different but bleeding it won't adjust it at all
Old 02-12-2012, 01:28 PM
stags
stags's Avatar
RUN from Royal Purple. I used that and within 100 miles was convinced I was going to have to have the synchros replaced. Put amsoil in and havent had a problem since.
stags is offline
Old 02-13-2012, 10:52 AM
157dB
Cut & Paste Expert
157dB's Avatar
Run to AMSOIL.
Avoid the inferior Royal pain in the **** Purple.
Put the AMSOIL ATF in the tranny and its slick as greased pig.
Problematic shifting disappeared. Cold weather operation
is just as warm weather. Smooth.
CLUTCH BLEEDING PROCEDURE:
Point the stang uphill at a 45 degree or better
and fully depress and release the clutch a few
times to fully bleed the system.
157dB is offline
Old 02-13-2012, 10:59 AM
up_yours_7
up_yours_7's Avatar
So I'm going to try this out and swap my royal purple for amsoil and see if there is a difference
Old 02-13-2012, 11:19 AM
gmoran1469
gmoran1469's Avatar
Well for one you put automatic transmission fluid in a manual transmission, that may be one thing wrong, but it may not affect it much, I don't know to be honest.
Also, the correct fill level is 1/2 inch below the fill plug so if you filled it till it overflowed then you put too much.
I used RP Synchromax and it works fine, much better than the stock fluid, 55k miles on my 09' GT.
gmoran1469 is offline
Quick Reply: Manual Tranny fluid recommendation? (other than ATF)
