Check Engine Light - U1900 & P0174
Old 04-17-2012, 10:27 PM
sainraja
sainraja's Avatar
Default Check Engine Light - U1900 & P0174
My car has the check engine light on and I've used the OBD diagnostic tool and these are the two codes I get:
  1. U1900
  2. P0174
I have tried Googling, only to be left a bit more confused. So I thought I would post here and see if you guys can help.
I've had the car in the shop a few times already and I am not really looking forward to it going back again. After having the car back the first time, the check engine light came on and disappeared the next day so I thought it was a l good (it went on it's own.) Now it's back and giving a different code (the second code, the U1900 code came before as well.)
sainraja is offline
Old 04-18-2012, 03:26 AM
Rshustler1
Rshustler1's Avatar
The u1900 code refers to a short in one of your modules. Example your pcm ( power control module) so in you need to get a manual and start checking all the modules. Electrical gremlins can be a real pita. The p0174 code refers to system running lean in bank 2. Maybe they coincide with each other which could be a good place to start. Find the module that controls air fuel ratio.
Rshustler1 is offline
Old 04-18-2012, 08:19 AM
sainraja
sainraja's Avatar
Thanks.
I need to get a hold of the manual then.....the workshop that repaired my car still has it. I have to go get that first and hopefully figure this thing out.
sainraja is offline
Old 04-18-2012, 11:22 AM
GrayPony
GrayPony's Avatar
I would check to make sure the car does not have the dreaded passenger side water leak trashing the smart junction box.
GrayPony is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: Check Engine Light - U1900 & P0174
