Strut and shock replacement
Can someone provide a good DIY link for this work. I've searched and could not find a simple diy. Also, do you have to remove/compress springs for the front struts, or do you do springs at the same time?
http://iihs.net/fsm/?dir=52
Hopefully this link works.... It'll take you to the workshop manuals in the suspension section, you can click on front suspension then removal and installation and then the struts and springs.... It's pretty straight forward, I've done it several times.
How to change them and the
and http://www.ebay.com/itm/MONROE-72138-Front-Strut-Assembly-/330661695247?pt=Motors_Car_Truck_Parts_Accessories&hash=item4cfcf90f0f&vxp=mtr#ht_1102wt_1396 and http://www.ebay.com/itm/MONROE-5783-Rear-Shock-Absorber-/330661693616?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4cfcf908b0#ht_1102wt_1396 to do it.
While you are there you need to replaced the strut mounts as they will most likely be destroyed, plus this is a nice cheap upgrade from OEM.
Im going to get crap for posting an ebay link but i have had great results with Monroe struts and shocks and from ebay and their return policy.
also know that you have to get an alignment afterwards, most of the time this will cost about $60-$100 and can be done by most tire shops.
Go get em tiger.
Go get em tiger.
this video was a great help when I installed mine, basically tells you everything you need to know. http://youtu.be/WUZODaXmkYU
