Radio wont turn off!
First of all, this is my first post so hopefully I am doing it correctly.
Ok I have an 08 V6, and I just went out and noticed that even though the car is off, no key in the ignition, and its locked that the radio inside is on somehow. Everything seems to be working fine, but when I lock the car with my remote it normally beeps when its armed, but it wont do that. And when I unlock it with the remote normally the headlights and interior lights come on, but again...it wont.
Only modification i have done is add some LED interior lights about 2 weeks ago using a fuse tap for the power. I used an empty slot in the fuse box in the passenger side of the car and like I said I did this 2 weeks ago and this is the first time Ive had a problem.
Any ideas anyone?
Thanks for the help, im stumped!
Any ideas anyone?
Any ideas anyone?
Any ideas anyone?
Assuming that the radio is stock than it is definitely not normal for the radio to be on after the car was locked from the outside.. He said he walked to the car and noticed his radio was on and the car was locked...
That's a weird problem and not something I can even take a stab at right now.. Hmm, try disconneting and reconnecting the battery and see if that helps... Keep us posted though
Back when my OEM battery was dying, I had my radio go crazy one day on the road (around 45mph) and just stop playing, and all the symbols lit up (then the CD changer started shuffling with no CDs in it, etc).
It only stopped after I changed the battery out. It's well documented that these S197s do some weird *** things when the battery is dying, so if you haven't yet- try changing the battery out.
Thanks guys but for whatever reason it seems to be okay again. Hard to isolate the problem when it isn't consistent. If it happens again I will do a little more tinkering and see what I can come up with, but for now im just happy that its working right. Such a terrible feeling when your beloved car starts to have an issue or gets a ding! haha
Take care guys
Take care guys
Josh, as mentioned above, this may be a voltage issue as the S197's are very persnikity about proper voltage and the charging systems are barely of marginal quality and capacity. Have the battery and alternator load tested. Many gremlins have been associated with degraded/degrading alternators and/or batteries. The degradation of one often leads to the degradation of the other in this model.
But if that's not the problem, then you may want to check the front passenger carpet by the kickpanel for moisture after the car has sat out in heavy rain.
Take care guys
Take care guys
