Actual Push to Start?
Old 01-06-2013, 08:23 PM
Mustang_Lover05
Mustang_Lover05's Avatar
Default Actual Push to Start?
I was wondering if there were any way to modify the American Muscle Push button start to a secret toggle switch somewhere else in the car? This way teh push button start would only work if you flipped the other switch wherever you placed it? I think it would be even cooler if you could modify the switch to not have to use the key, but i think that would require serious modification. Any suggestions?
http://www.americanmuscle.com/sr-mus...tton-0509.html
Mustang_Lover05 is offline
Old 01-06-2013, 09:01 PM
Ant-Man
Ant-Man's Avatar
Not require a key to start the vehicle? Not the smartest idea in my book.
Ant-Man is offline
Old 01-06-2013, 09:24 PM
Mustang_Lover05
Well thats what the other hidden switch would be for incase anyone broke in. Kind of a killswitch but not exactly. It could be hidden in the console under that little piece that pops out on the left of the 12V connector.
Old 01-09-2013, 07:31 PM
astentine
astentine's Avatar
Technically, if took one of the live wires from the push button start and put a switch on it, then the push button would not work unless the switch is on (i.e. the wire you tapped into is connected again). As far as removing the key from the equation, that would be more difficult. However, it is essentially a switch as well. When the key is in and "on" the switch is activated. You would just have to bypass the "on" position and run it to the new switch so when it is turned on, the car is "on" and the push button would work.
Actually, this seems like a really neat idea. Best of luck, keep us posted.
astentine is offline
Old 01-10-2013, 09:25 AM
teepee542
teepee542's Avatar
you could alway do This
more money but cleaner...
teepee542 is offline
Old 01-19-2013, 11:50 AM
157dB
Cut & Paste Expert
157dB's Avatar
I would not go with that as the install instructions are
posted right there for all to see.
I have already figured out how to by-pass that system
just from reading the install instructions...
http://www.gallotech.com/GTS2-manual-rev82-20212.pdf
Plus the picky PATS chip that is in the key that the
PCM WANTS to see a few seconds after the engine starts...
If no PATS chip, the engine promptly dies...
http://iihs.net/fsm/?dir=411&viewfile=Anti-Theft.pdf
ByPassing anti-theft invites joy riding and theft.
Be glad your Stang cannot be hot wired by 99.99999999999%
of the US population (unless the criminal works at
a Ford dealership).
157dB is offline
2007StangV6
01-28-2016 06:09 PM
raleigh05GTO
09-04-2015 07:09 AM
Emblazoned
09-03-2015 10:45 PM
5.0 kevo
09-03-2015 06:24 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: Actual Push to Start?
