pony pkg stripe
Old 02-22-2013, 01:47 PM
zworld
zworld's Avatar
Default pony pkg stripe
I'm wanting to remove this, any tips to this?
zworld is offline
Old 02-22-2013, 03:15 PM
svastano
svastano's Avatar
Heat gun
svastano is offline
Old 02-22-2013, 04:35 PM
rls82959
rls82959's Avatar
I peeled mine off very slowly. Came off easy & clean.
A little heat may be needed during a cold Kansas February.
rls82959 is offline
Old 02-23-2013, 06:31 PM
ebritt
ebritt's Avatar
I used a vinyl stripping/decal removal wheel from a local paint shop. About 30 bucks. used it to get started then peeled off by hand. Easy peezy
ebritt is offline
Old 02-23-2013, 07:19 PM
Keep it real
Keep it real's Avatar
I used a box blade type blade and went very slowly.
Keep it real is offline
Old 02-23-2013, 09:12 PM
J_Novulls
J_Novulls's Avatar
I just did this last week. I'm in MD in 35 degree weather. I used a heat gun to get the stripe off and then some alcohol in a cloth to get rid of the shadow. It came out great, but I was freezing!
J_Novulls is offline
Old 02-26-2013, 11:44 AM
157dB
Cut & Paste Expert
157dB's Avatar
Wrong in so many ways.
Heat gun and pull at a 180 degree angle
to the paint, not at a 90 degree angle.
The paint will be less faded under the stripe
and a 'ghost stripe' may be in its place once
the stripe is removed. Beware...
92% alcohol will remove the remaining adhesive.
Follow this up with a good paste wax.
157dB is offline
Old 02-26-2013, 11:51 AM
07 Stang
07 Stang's Avatar
I wonder if you will have a ghost stripe left behind? I have read many take theirs off during the summer months when the sun heats up the vinyl. Using a heat gun + on a hot summer's day will help get it off better without breaking into many pieces.
07 Stang is offline
Old 02-27-2013, 07:13 PM
zworld
zworld's Avatar
the stripe is removed. Beware... 92% alcohol will bemove
the remaining adhesive. Follow this up with a good
paste wax.
Beware what? That alcohol will remove adhesive? That makes no sense.
zworld is offline
Old 02-27-2013, 08:45 PM
maxshuty
maxshuty's Avatar
He means there will be a residue left behind, similar to if you put duct tape on something for a month and peel it off - there is a residue. Use alcohol to rub that residue off.
Personally I would wait until summer to remove them and just use a blow drier. That's what i used to remove my door ding strips. Wash & Wax your car right after you do this too.
If you have an older car you may want to peel off a tiny corner and shine a bright light and see if there is a ghost stripe underneath, in which case you may just want to leave the stripes on.
maxshuty is offline
Quick Reply: pony pkg stripe
