4.0 Valve Cover removal
Old 04-30-2013, 11:56 PM
Jasoon
Jasoon's Avatar
Default 4.0 Valve Cover removal
So I Finally have a possible plan to paint my mustang's Valve covers.... and the paint guy tells me he'll cut the price in half if I'll be the one to remove and reinstall the valve covers & Strut Tower Bar after painting. I got a Ford Boss Strut Tower Brace, but the silver metal looked really out of place with so much underhood stuff painted copper.
I've removed my Dakota's Valve covers before, and what an ordeal that turned into. Engine slightly under the cab of the truck, 14 bolts per side, Brake booster in the way, new gasket didn't seal so I actually had to do one side 3 times.
SO, the real question is how much effort is needed to remove the V6 valve covers?
As for installing the strut tower brace: Remove 2 screws from either side, slide on brace, put on new screws and torque them down. Am I missing anything? (Yes, I got 4 new nuts because I read that Ford says they are single use nuts)
Jasoon is offline
Old 05-01-2013, 12:23 AM
akdoggie
akdoggie's Avatar
I have replaced the ones on my 07 with painted covers. It wasn't a big deal. Fairly simple and straight forward. I found that on the right side, you remove the battery for full access to the cover and no problems. The left i tighter, but isn't that difficult. The gaskets sit into seams, so they won't leak. You won't have much problem doing it yourself. Just remember you need a deep socket for the long stemmed studs. Other than that, I can't think of anything that is in your way. You'll like the look when it's done.
akdoggie is offline
Old 05-01-2013, 08:18 AM
2005Redfire6
2005Redfire6's Avatar
Its not too much of a pain in the ***, def. doable without driving you crazy.
2005Redfire6 is offline
Granatelli Sales
01-20-2020 12:34 AM
LivingInThePast
09-16-2015 12:20 PM
prophotog
09-15-2015 08:38 AM
FivePointToTheOh
09-14-2015 03:35 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: 4.0 Valve Cover removal
