If you have water in trunk.... - MustangForums.com
Sponsored by:
Sponsored by:
Old 07-12-2013, 10:56 AM   #1
Paul_VS
Paul_VS's Avatar
Default If you have water in trunk....
I've noticed a few threads on this subject so if you have the problem this might be the cause.....
I noticed a couple times since I got my car that the carpet in the trunk was wet on the right side. I didn't think much of it - assumed it was a leaking water bottle or something I had in the trunk. Then I grabbed a jacket out of the trunk last week and it was really wet, so I took it to the dealer.
Turns out the rear window was leaking where the defroster plugs in -- it wasn't sealed properly. They called out a glass guy who pulled it off and resealed it. They tested it and it didn't leak anymore.
Paul_VS is offline   Reply With Quote
Old 07-15-2013, 03:57 PM   #2
flyhigh@mach1
flyhigh@mach1's Avatar
Good for you....Ford seems to have multiple leak issues on these S197's
flyhigh@mach1 is offline   Reply With Quote
Old 07-16-2013, 12:12 PM   #3
MustangFirstCar
MustangFirstCar's Avatar
Also, just in case anyone is searching for solutions to this and come across this thread, I'd like to say that the water can be easily drained out by removing the floor mat and spare tire and then pushing down on one of the drain plug grommet things at the bottom (wires are routed through it until it pops out. I know this seems obvious but it took me a full day to figure that out so in case anyone else doesn't know I thought I'd post it.
MustangFirstCar is offline   Reply With Quote
Old 08-17-2013, 03:50 PM   #4
157dB
Cut & Paste Expert
157dB's Avatar
Quote:
Even more obvious is to make sure that you
REINSTALL or pop the drain plug back in after
draining the water.
If not, you will have a wet spare tire well the
next heavy rain drive you take...
157dB is offline   Reply With Quote
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 04:23 PM
Possible Clutch Issues..? Thunderball 4.6L (1996-2004 Modular) Mustang 15 11-22-2015 11:49 PM
2014 convertible water drains jerrytubes 2005-2014 Mustangs 2 10-23-2015 12:11 PM
Original Owner 1970 Mustang b8checker Classic Mustangs (Tech) 8 10-08-2015 12:55 PM
Water found on Mars! HRnB Off Topic 31 10-01-2015 05:50 PM
