pinion flange from 7.5 to 8.8?
Old 08-06-2013, 10:41 PM
grogan
grogan's Avatar
Default pinion flange from 7.5 to 8.8?
http://www.americanmuscle.com/frpp-p...0304cobra.html
is this the flange that is needed to go from a 2008 v6 7.5 rear to a 8.8 rear. im going to a 2011 gt rear but its all the same from 05 to 13 in the 8.8.
just not sure what else I need to make this work. haven't grabbed the rear yet, want to do my homework making sure I don't need to spend more money than this is gonna cost me.
grogan is offline
Old 08-07-2013, 06:43 AM
2007StangV6
2007StangV6's Avatar
Yep, that is the flange to go to a 8.8.
I want to say I read somewhere that if you are getting a 2011+ 8.8, then you don't need the cobra flange. I can't remember where I read it though, but am pretty sure it was on here.
2007StangV6 is offline
Old 08-07-2013, 09:33 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
Yeah this is a pretty basic swap. The suspension set up is basically the same so you just need to throw the 8.8 diff in there and some sort of 8.8 pinion flange. A lot of guys do use the 03/04 Cobra Pinion flange!
I hope this helps. Let me know if you have any questions or need some assistance! -Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266.
-Dan
AMDanBailer is offline
Old 08-10-2013, 09:19 AM
157dB
Cut & Paste Expert
157dB's Avatar
And a new crush sleeve.
And a new pinion nut.
Be sure and get the pinion preload right
or that new 8.8 will toast prematurally.
157dB is offline
Old 08-10-2013, 07:48 PM
pascal
S197 Section Modder-ator
pascal's Avatar
I've done that swap...
That's the flange and it's all you need except maybe for a new pinion seal for good insurance.
pascal is offline
Old 08-17-2013, 09:20 AM
157dB
Cut & Paste Expert
157dB's Avatar
Yep, $4 items like seals should always be replaced when its feasable
when doing any kind of repair or swap.
Like only changing the outer whenn brearing/race on the boat trailer
and only on one side to boot. Do inners and outers and seals
when you have the item apart. And maybe both sides as well.
Like it only drives on one wheel part of the time and the bad
outer bearing/race was defective and the other three are still
fine?
157dB is offline
Old 08-17-2013, 08:25 PM
Moderator
JimC's Avatar
If you are getting a rear end from a 2011 check the pinion flange on it before swapping. It should already have the correct flange making it a direct swap. I used to have a source for rear ends to sell and the first time we sold one that came from a 2011 we discovered that the flange swap wasn't needed. (the supplier closed down so no, unfortunately I can't get the rear ends anymore)
Any rear end before 2011 you have to swap the flange. And the one you posted is the correct one.
JimC is offline
Old 08-24-2013, 06:31 PM
grogan
grogan's Avatar
ok, thanks guys, im grabbing the rear from Justin burcham's race car. his factory rear has less than 300 miles on it, so ill try swapping it directly and if not ill order than piece
grogan is offline
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
Matt's 95 Stang
10-05-2015 07:16 AM
KingRando
10-02-2015 08:06 AM
67LimeCoupe
09-30-2015 04:46 PM
Quick Reply: pinion flange from 7.5 to 8.8?
