Rear Rattle
Old 09-16-2013, 01:37 PM
Paul_VS
Paul_VS's Avatar
Default Rear Rattle
I thought this noise was some stuff I had in the trunk, but I took everything out of it today and the "clunk" is still there.
I put the rear seats down so I could try to locate it better.... best description I can give is that it sounds like a hollow wooden box is loose inside the driver's side rear quarter panel. Makes a clunking noise when going over a bump that "jolts" the car a little bit. Something is definitely loose and hitting something else. I'm wondering if it is the exhaust hanger issue, or maybe the fuel filler pipe banging into something.
I've got an appointment to take it into the dealer, but obviously would rather fix it myself if it's quick & painless.
Paul_VS is offline
Old 09-16-2013, 05:21 PM
Lifter583
Lifter583's Avatar
check your mufflers and pipes...
Lifter583 is offline
Old 09-17-2013, 01:05 PM
Paul_VS
Paul_VS's Avatar
Dealer fixed it... it was the sway bar end link. Seems to be a common problem with this model. They replaced both of them.
Paul_VS is offline
Old 09-20-2013, 10:22 AM
FordService
Official Ford Rep
FordService's Avatar
Thank you for the info, Paul_VS!
Deysha
FordService is offline
Old 09-20-2013, 08:52 PM
Paul_VS
Paul_VS's Avatar
Deysha
You're welcome.
By the way, do you happen to know if Ford has redesigned/improved these sway bar end links, or are the new ones most likely the same type that were originally installed?
Paul_VS is offline
Old 09-23-2013, 08:40 AM
FordService
Official Ford Rep
You're welcome.
I’m not sure, Paul_VS. Your dealer is able to provide you with this info. They can compare the part numbers and read the updates.
Deysha
Old 09-30-2013, 11:49 AM
Paul_VS
Paul_VS's Avatar
Deysha
Well I talked to the dealer and they said the replacement part # was the same, so it looks like there was no change.
Kind of disappointed in Ford on this since there is obviously an issue with them wearing out prematurely.... there are numerous posts on this problem stating that the links wear out in <20,000 miles in most cases.
It will most likely result in them wearing out again.... just about the time my warranty will have expired.
Paul_VS is offline
Old 09-30-2013, 03:32 PM
FordService
Official Ford Rep
I understand, Paul_VS. I recommend you keep your receipts in case any recalls come up in the future. Also, I’m happy to get this documented in your file as well. PM me with your VIN, dealer, mileage, full name, and best daytime number.
Deysha
AmericanMuscle4.6GT
11-10-2015 02:06 PM
2015Ecoboost
09-17-2015 01:48 PM
movielover40
09-15-2015 10:37 AM
robjh22
Suspension
09-08-2015 12:47 PM
tmdm
09-04-2015 06:45 PM
Quick Reply: Rear Rattle
