Exhaust Question
Old 10-08-2013, 12:24 PM
ModBargains
Former Sponsor
ModBargains's Avatar
Originally Posted by Jande063
It sounds like there is a bit of an exhaust leak somehere up front, I would check all four ends of your X-pipe, and check whether your O2 sensors are fully seated.
I have a few questions about the BBK long tubes for the 3.7L. I was wondering if anyone happened to know the difference in underhood temps between the stock manifolds, the chrome long tubes(should be vey close to stock temperature), and the ceramic coated long tubes(should be lower, but by how much)? Also, how does the ceramic coating hold up over time, and is it ok to use header wrap to further insulate against heat transfer to the general engine compartment, and the same for the chrome coated tubes? Thank you for your time.
Very good question which I feel should be answered as well, but the thing is, the only way to get a perfect example of how much it lowers temps is to put the car in a controlled environment so that the outside temperature is the same when you compare the ceramic vs non-ceramic.
We know for sure ceramic coating does drop temperatures, but the likelyhood of anyone finding the exact number in which the temperature decreases is going to be hard to find. Regardless, I do enough road racing to get the ceramic coat, so I would go for it anyway, it's not too much more, so might as well.
ModBargains is offline
Old 10-08-2013, 01:57 PM
2011V6Nicole
2011V6Nicole's Avatar
Im not sure about the actual temps but the chrome ones put off more heat than the stock manifolds just based on opening the hood after driving for a while. Luckily I have vents in the top of my hood so the heat from the headers goes straight up and out
2011V6Nicole is offline
Old 10-08-2013, 08:10 PM
baibbas
baibbas's Avatar
Nope, not up front...the O2 sensors are seated so tight it's not funny and have loc-tite on them...the headers are on tight as well....made sure all the nuts threaded easily before tightening them down....
The smell is coming from under the car near the rear, so my dumb butt didn't raise the pipe enough before I tightened the clamps...duh on me!
The only other smell is the ceramic headers curing.
baibbas is offline
Tivo304
08-28-2023 12:19 PM
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Exhaust Question
