throttle body help needed
Old 12-26-2013, 08:06 PM
Uncle Paw Paw
Uncle Paw Paw's Avatar
Default throttle body help needed
I have a 2011 3.7 that went into reduced power mode.
Code P2111.
I cleaned the throttle body and reset the ECU.
It still goes to reduced power mode when driven a short distance.
Do I need to replace the throttle body or is there a fix I do not know about.
All advise will be greatly appreciated.
48000 miles. Warranty went out in June.
Uncle Paw Paw is offline
Old 12-27-2013, 10:27 AM
Moderator
JimC's Avatar
If you cleaned the throttle body so that the plate isn't binding, then I would check the wiring next. And get some electrical cleaning spray and clean the contacts too.
Any modifications to your car?
JimC is offline
Old 12-27-2013, 11:47 AM
Uncle Paw Paw
no modifications and I have cleaned the wiring today to no avail.
Still searching and my daughter is wanting me to get her car on the road.
Old 12-28-2013, 10:21 AM
Moderator
JimC's Avatar
Then you've done the easy stuff - so next up would be the actual throttle body motor has an issue. Do you know anyone near by who would let you swap their throttle body on and see if the problem continues? Otherwise, go to the junkyard and try to pick up a throttle body cheap
JimC is offline
Old 12-29-2013, 12:57 PM
Uncle Paw Paw
Thanks for the help. I did what was recommended and now I see that a new throttle body is the solution. I appreciate the input. Sometimes I just need a different view or some knowledge fromm experienced individuals. I enjoy repairing things myself and I am really good at taking this throttle body on and off so. I was pleased to see that a brand new one is not as expensive as the first Ford dealership offered it to me for. Used price is exceptionally easy on the pocketbook.
Old 01-05-2014, 09:24 AM
Uncle Paw Paw
putting on the new throttle body Monday afternoon.
Are there any tips on new equipment instillation that I need to know. ECU, etc....
I am putting a genuine ford part new throttle body.
Thanks in advance.......
Old 01-12-2014, 08:34 PM
Uncle Paw Paw
Just to let everyone know that the new $228.00 dollar throttle body fixed my problem.
Old 01-13-2014, 06:09 PM
Nuke
Nuke's Avatar
Superb.
Nuke is offline
Old 01-13-2014, 07:22 PM
shinerttu
shinerttu's Avatar
Congrats, glad it was an easy fix
shinerttu is offline
Old 01-14-2014, 11:17 AM
kevinmalec
kevinmalec's Avatar
Good to hear the new TB fixed the issue!
It seems odd to me that the TB went bad in a 2011. :/
kevinmalec is offline
Quick Reply: throttle body help needed
