ABS & Traction Control
Old 01-17-2014, 08:08 AM
teetertotter
teetertotter's Avatar
Default ABS & Traction Control
Both ABS and Traction Control dash lights came on a couple days ago. Naturally, both systems are in off position. When I press the traction control button, the off light still stays on.
We have had a lot of snow, rain mixed, SLUSH galore, and freezing Temp in the 20's. Just wondering if there are wheel sensors and snow slush has gotten on the sensors and frozen.
I am wondering if things should thaw out when temps get into the 30" and run through car wash with underbody wash to clear the sensors and see if that works. If that does not work, then take it to my local mechanic.
Details of my car are below.
teetertotter is offline
Old 01-17-2014, 09:46 AM
157dB
Cut & Paste Expert
157dB's Avatar
It appears that you might have the wet SJB syndrome.
Search "leak" and read all about it...
157dB is offline
Old 01-17-2014, 10:45 AM
teetertotter
Got it. Everything corrected itself early this morning. Then system went off again later this morning. So, will not do anything until things thaw out and what not.
Old 01-22-2014, 11:36 AM
teetertotter
ABS and Traction control has been operational for 2 days now. I still have not taken car to car wash for underbody wash..etc. Under carriage is still full of salt, frozen slush, and frozen water. The sensors must have cleared themselves of whatever for the time being.
Old 01-23-2014, 12:06 AM
tx_zstang
tx_zstang's Avatar
As noted, your sjb probably got wet. Do a search, there's easy fixes and it is a very common problem. Dont leave that salt and crap on there!!!
tx_zstang is offline
Old 01-23-2014, 10:14 AM
teetertotter
wrong thread
Old 03-14-2014, 08:15 AM
teetertotter
Update:
The intermittent ABS light comes on if car has slush or perhaps freezing water somewhere on the undercarriage. I leave the ABS light on until I feel like going to the car wash w under body flush.
Old 03-24-2014, 08:41 AM
massguy54
massguy54's Avatar
mine comes on every now and then and don't drive in snow
massguy54 is offline
Old 10-08-2014, 02:30 PM
teetertotter
Update: The ABS and traction light has been steady lights for a couple months. This morning the lower radiator thermostat was spraying water on the engine producing steam when antifreeze hit the engine block. I made it to my volunteer morning job. I had the car towed, via AAA, to my local mechanics garage to have lower thermostat replaced along with 3 hoses. Latter, I called my mechanic again to have him trouble shoot the ABS Traction Control system. Called me back and said was the rear wheel drivers side wheel sensor. I will pick the car up tomorrow. With snow season drawing near, need the ABS Traction Control System fixed. Snow tires go back on late November.
WINTER!! GRRRR
Old 10-18-2014, 07:14 AM
Nuke
Nuke's Avatar
Snow? And I'm freezing at 56 degrees at sun-up this morning. Must be one reason I moved from the north.
Good luck on this issue. Continue to keep us posted.
Nuke is offline
Quick Reply: ABS & Traction Control
