Long Tube headers for my six
Old 06-09-2014, 08:39 PM
Siber Express
Siber Express's Avatar
Originally Posted by 2005Redfire6
Shorties do little to nothing power wise to justify the ordeal to install them, might as well go long tubes!
This is your opinion, The pick up in the low to mid range in torque is more than worth it.
If I use your analogy long tubes are worthless since the power is all in the high end, not so good for a DD.
I don't usually cruise around at 6000 RPM, but I do cruise around at 2000 RPM and the shorties sure help down there.
Siber Express is offline
Old 06-10-2014, 06:29 PM
yourmom6990
yourmom6990's Avatar
Thumbs down
You sir, are wrong!
yourmom6990 is offline
Old 06-11-2014, 06:18 AM
2005Redfire6
2005Redfire6's Avatar
Cool, you have dyno sheets proving so or is this just the butt dyno?
Originally Posted by yourmom6990
Nice, you send me a manufacture video 14-16rwhp my ***.
2005Redfire6 is offline
Old 06-11-2014, 10:08 PM
yourmom6990
don't talk to your mother like that. Numbers don't lie my *** friend.
Old 06-11-2014, 10:14 PM
Siber Express
Do I have a Dyno from before and after? No.
Do I know what my car does differently from before the header install and what it does after? Yes.
Do I have to worry about the $25,000 fine for removing my OEM Cats? No
BTW that is up to $25,000 for removing or Modifying a pollution control device.
Are Long Tubes really worth having to pay a fine that large? No.
So knowing someone that did get a $15,000 fine for having other than OEM cats on their truck (High Flow Cats on his F-150) that was reduced to $1500 after putting the stock exhaust back on it just is not worth it to put on long tubes.
I will stick to the shorties that are CARB approved, the OEM Cats and resonators and enjoy the low to mid range usable torque that they offer.
Old 06-12-2014, 06:27 AM
2005Redfire6
Ahhh yes, trying to justify wasting your money on shorties. I see what you did there!
Ummm...
Old 06-12-2014, 10:46 AM
JayBeStangs94
JayBeStangs94's Avatar
BBK Shorties here also, and they now have their CARB Approval so they will pass smog in California.
I know it has been longer than a month Jay but have you gotten the long tubes yet?
Nope haven't ordered them! Just about to put coilovers on, and just ordered wheels so I'll need to save again!
Tell me about your headers, how do you like them? I have decided against the long tubes for ca standards as well as the unreasonable sound. I may consider going with the shorties for the little added upgrade.
JayBeStangs94 is offline
Old 06-12-2014, 04:17 PM
yourmom6990
http://www.americanmuscle.com/best-f...g-headers.html
Don't listen to redfire. Shorty headers will give you a noticeable torque gain. He is obviously uneducated when it comes to shorty vs long tubes.
Old 06-12-2014, 09:14 PM
Siber Express
I do not need to justify my choice to anyone since the gains are there and more than one person has dynoed them with much large low to mid range torque and HP gains than long tube. The only place long tubes did better than the shorties on the 3.7 is in the top end. Since corner carving uses more of the RPM range than just top end no justification is needed to you or anyone else.
And then you have the Raspiness that you need to get rid of or drive you crazy if your car is a daily driver. After having ridden in a car with long tubes there is no way on God's green earth that I would have put long tubes on, even if they were legal for other than off road use.
Oh as for the comparison
Shorties Long tubes
60' 1.808 1.806
1/8 8.192 8.105
1/8 mph 84.96 85.02
1/4 12.785 12.649
1/4 mph 107.04 108.85
DA 1904 671
1/4 DA 12.507 12.576
1/4 mph DA 109.48 109.45
Same car in the Shorty VS Long Tubes, so they are a waste, I think not.
Ummm...
Comparing the Shorties VS Long tubes was done on another site and the loss was little more than a 10th in the Quarter mile.
As for me it wakes the 3.7 up, it gives it a modest torque bump where the 3.7 needs it the most in the low to mid range. It is probably the best legal performance mod out there that actually changes power over just enhancing it like gears would do. Then there is the fact that after you car is old enough for smog you don't need to find a crooked smog station of put the stock stuff back on to get it to pass. I miss the Beach, but that is all I miss about California.
Old 06-13-2014, 01:21 PM
Bob T
Bob T's Avatar
Most of my knowledge/experience is from a long time ago with Chevy engines but let me list some generalizations that applied then and tell me if they still hold true (my memory may not have these quite right):
Bigger diameter tubes are better for larger cubic inch and/or higher rpm engines.
Smaller diameter tubes and better for smaller cubic inch and/or lower rpm engines.
shorter length tubes contribute to a higher rpm torque peak.
Longer length tubes contribute to a lower rpm torque peak.
On a side note the header collectors I see on headers available for the 3.7 V6 (especially on the short tube headers) all look too short and inefficient.
Bob T is offline
Jb145700
08-21-2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
10-22-2015 11:55 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: Long Tube headers for my six
