Growling noise from the front
Hi guys,
I have a beautiful 09 V6 which I brought as Used from a local dealer about an year ago, I absolutely love it. There has been an issue since the beginning with the noise from the front end, I could never be sure.
Here is the description of the noise: It doesn't start initially, I should be driving the car for about a half hour for the noise to start and it becomes louder as I accelerate. When I change to neutral and release the clutch the noise gets worse and dropping the speed below 30 will shut it off. I tried 3 shops and they couldn't reproduce the issue. But it happens to me every time.
Has anyone been through this kind o issue? What could this problem be about?
Stats: 2009, V6 3.7L, 40K miles, serviced regularly.
Thanks in advance
Yash.
Thanks in advance
Yash.
Can you better describe "growling"? At a rough guess, I'm thinking wheel bearings or a dragging brake pad. I'm not sure what under the hood would cause the sound based on what you describe based on speed and clutch operation. When it's "growling" and you're in a turn, left and right, what happens?
Hi guys,
Thanks in advance
Thanks in advance
I recommend you speak to your service manager at your Ford Dealer. He is in the best position to ensure a proper diagnosis, and will be able to provide available options and/or coverage for any work needed. Also, remember repairs done at a Ford Dealer come with a 24 months/unlimited miles warranty.
You can schedule an appointment online here.
Deysha
Interesting....this is the first I've heard of this.
Are you able to record the growling sound and then post the video?
My Wife's old Grandam would make a growling sound when making a tight right turn. It ended up being a bad wheel bearing.
I hear chattering noises near my shifter or behind my A/C *****.
If you're hearing it with the vehicle stationary, then rule out brakes and wheel bearings. It could be water pump, alternator or a pulley problem if occuring when stationary.
jwog666
12-27-2021 08:09 PM
