Mod help for 2006 V6 Mustang (Manual)
Old 08-03-2014, 07:11 PM
Madrox
Madrox's Avatar
Originally Posted by jimkaray
If this is your main goal:
To max out your bang for the buck remember that a fancy CAI intake tube is purely cosmetic, you can just buy a high flow filter and get the same added air flow and sound. So called no-tune CAI's often end up needing a tune as the computer controls are very picky and that leads to a lot of deals on used CAI's.
Free tunes are nice but you have no plans for any mods for at least 4yrs it seems. At that time you may or may not keep the car and who knows what the tune/tuner market will look like in the future. I imagine the standard handheld will phase out and move onto your phone. Custom tuning cost has steadily gone up so if that trend continues AND you keep the car and BAMA is still in business (just being realistic, not a prediction) then lifetime tunes is a deal.
I wouldn't count on a mileage tune paying for itself but the tuner is a big help in reading and clearing trouble codes. This plus having the Forums and google can save you a lot of cash when issues pop up and you need to know what is wrong.
Really, the only performance mods I want are the tuner, CAI, and eventually a true dual exhaust. Would I need a re-tune upon installing a dual exhaust? If not, then passing on the free tunes wouldn't be a big deal at all.
I've also been getting a pain in the *** P0420 code that seemingly cannot be eliminated. So for that reason alone, a tuner sounds nice.
Madrox is offline
Old 08-03-2014, 08:32 PM
yourmom6990
yourmom6990's Avatar
A CAI with out a tune is not a good investment, they are known to throw codes with out one and really are not able to do much more than sound good until you add a tune.
"Known to throw codes"?? Not sure where you are getting this information but this is certainly not true. I have never had a vehicle throw a code from an intake nor ever heard of it until now. Unless someone puts a tune-required intake on with no tune I don't see how a CAI would throw a code. The non-tune intakes use the same diameter as stock if not slightly larger. The computer will adjust to the CAI. Sure, with a tune you're going to see better results, but there will still be noticeable/minimal gain without a tune.
You don't NEED to retune the vehicle for those mods, but it would definitely be beneficial to see the most gains. As for the P0420 code, check out this thread... https://mustangforums.com/forum/v6-s...0-problem.html
If you erase it and it comes back, I would consider checking your O2s.
yourmom6990 is offline
Old 08-03-2014, 10:15 PM
jimkaray
jimkaray's Avatar
If you've been following the 4.0 forum for any length of time you would be aware of this issue. Its not a huge problem but not uncommon. The question is bang for the buck so a little bang with maybe 30% chance of no bang at all I can't recommend for his situation. Try a search on Tune CAI Code or some other key words and you will see what I'm talking about.
examples:
https://mustangforums.com/forum/4-0l...t=CAI+code+CEL
https://mustangforums.com/forum/4-0l...=tune+CAI+code
https://mustangforums.com/forum/v6-s...=tune+CAI+code
And a generic google search for CAI and CEL issues
jimkaray is offline
Old 08-03-2014, 11:04 PM
yourmom6990
examples:
Weird.. This is the first i've heard of it. I had an 05 4.0 that I put an intake on and it ran smoothly. Guess it's just the luck of the draw.
Old 08-04-2014, 12:36 AM
Madrox
Madrox's Avatar
examples:
Looked into the reviews for a cheap "no tune" $100 CAI on AM. I found some of the complaints you are referring to. However, looking at the Airaid CAI, there are no complaints regarding this that I could find.
Gotta love risk-taking, though...
Also, regarding the code I've been getting, I already replaced the spark plugs, O2 sensors, and checked for vacuum leaks and found nothing. Next thing I'll probably do is check for an exhaust leak...trying not to get too off topic here, though.
Madrox is offline
Old 08-04-2014, 12:54 PM
kevinmalec
kevinmalec's Avatar
In the past, I purchased the Airaid CAI and installed with no custom tune and drove around close to 8 months and experienced NO issues. However, the performance gain was minimal and was only felt in the higher RPM range. Once I uploaded my custom Brenspeed tunes, I felt an instant change in performance! It felt like a totally different car. =)
If money is tight, purchase the Airaid CAI first, then save up for the SCT hand held tuner with custom tunes and add it later. That's exactly what I did!
BTW, Airaid is the same company that produces the Roush CAI, which is a very reputable company!
kevinmalec is offline
Old 08-05-2014, 05:29 AM
6xStang
6xStang's Avatar
deleting my post; I did not realize that I popped into the V6 section by mistake. Sorry.
Last edited by 6xStang; 08-05-2014 at 09:24 AM. Reason: Mistake; I didn't realize that I was in the V6 section
6xStang is offline
Old 09-01-2014, 10:43 AM
157dB
Cut & Paste Expert
157dB's Avatar
The dual exhaust will increase the eargasim quotient but
not the performance aspect as the OEM exhaust flows
free enough compared to OEM exhausts of the past.
The biggest bang for the buck in the muffler dept is
an OEM GT M/T passengers side muffler take-off.
In the suspension dept, front and rear GT take-off sway bars
along with Polyurethane bushings will help the handling 100%.
Especially if your V6 has no rear sway bar...
Base model V6es have NO rear sway bar and only
a small 31.5mm front sway bar.
Only Pony Packages had a 18mm rear sway bar.
Pretty squirly cornering under power with no rear sway bar...
Attached Thumbnails Mod help for 2006 V6 Mustang (Manual)-gtmufflerauto.jpg   Mod help for 2006 V6 Mustang (Manual)-gtmufflermt.jpg   Mod help for 2006 V6 Mustang (Manual)-springsshocks.jpg
157dB is offline
Old 09-01-2014, 06:02 PM
Madrox
Madrox's Avatar
So are you saying that replacing the stock muffler with a GT takeoff would be more/equally effective than getting a dual exhaust conversion kit? Or are you simply telling me it's a lot cheaper with almost the same effect?
Appreciate the advice on the suspension, but honestly, I'm perfectly content with the handling as is. Right now, I really just wanna focus on HP and also getting a badass sound.
Also, I read up on the differences between these two CAI's on the manufacturer's website (http://www.americanmuscle.com/airaid...ai-0509v6.html and http://www.americanmuscle.com/airaid-cai-0509v6.html). However, it did not seem to specify which CAI performs better. Can anyone clarify this for me?
Madrox is offline
Old 09-01-2014, 10:50 PM
JJHoover
JJHoover's Avatar
I imagine they both perform equally well with the only difference being maintenance.
JJHoover is offline
kevsgt
10-09-2015 10:12 PM
BeatnikFink
10-01-2015 08:00 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Mod help for 2006 V6 Mustang (Manual)
