Another vibration thread
Uh, yeah, sorry about starting the quadrabillionth "s197 v6 vibration" thread but I feel I need to.....
Ok my ride is a 2008 v6 auto mustang, Bama 93 race tune. When car is warm, in Drive, stopped, there is an annoying vibration. Put it in Neutral it goes away. If the fan is on, it vibrates even more! And now I am hearing a chirp. kinda intermittent like a nasty bird, not too loud though. WTF? Blower moter works, it blows fine, all settings work. AC fine(I think). Uhh maybe its in the driveline? like a worn Ujoint? But that should have nothing to do with the blower.
If I drive away the chirp and vibration goes away.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Alex
Thanx for the feedback alex and mechanic. I have not taken it in (yet). Don't want to. I was thinking maybe a loose motor mount but if all s197's do this then its just an engineering flaw. But I still don't get the chirping sound when the fan is on thing. I'll check out the motor mount threads
Alex
Mine does the same. Happens when there is an electrical draw on the engine, fan, ac, even the stupid turn signal makes the idle roll right on queue with the blink. Has driven me nuts. After replacing everything, throttle, intake, plugs, wires, MAF, pcv, alternator, etc. etc. and having three mechanic places look at it. The story is that my engine runs lean at idle, not enough to throw codes, just lean enough to not take the initial load when something turns on. Motor mounts are good, no bounce or play at all. So if you figure out what the problem is, let me know!!! Good luck!
Okay so the other day I had the fan off and I got that squeaky chirp at a stop. So it may not even be fan related. But when I go it goes away and Ive read b4 that as long as it goes away when you drive your fine. *keeps fingers crossed*
Check your harmonic balancer. 4.0 had problems with them coming apart. I was lucky when mine did it slid to the back. Guy I work with had his come off the front. It wiped out everything in the front along with his hood. Imagine a pound of steel spinning at 3000rpm.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
