My $1300, 2005 Mustang
#201
if you feel between the engine and battery down on the fire wall, you will find a rubber drain for the cowl area where the cabin air filter goes. there is one on the drivers side in the same relative location. check to see they are not plugged. in your case though, I think you've found the culprit. those foam gaskets on the cowl clips do not seal very good at all. there are 10 of them in all. you can get new ones that come with heat activated adhesive. I went the cheap route and got some autogoop and used that to seal the clips. I also used some dynomat around the harness/grommet above the SJB. if you remove the glove box and look up, youll see what I mean. Hell of a job BTW on bringing this pony back to life. good luck
#203
Wow, I hope you can locate the leak. You could do a search on the main forum and see all the different locations people found but most commonly it was the drain plug. You seem to be the type of guy who isn't afraid to get in there and take care of it. Wished my husband was that way with cars! He doesn't understand the fascination I have for cars.
#206
We got a foot of snow here in Kentucky last night so I am stranded at home. Read all 21 pages of posts. I am truly impressed. I do not think I could tackle such a project but I truly respect those who have what it takes to master them. I am sure there will be small issues for some time to come but it looks like you have the major ones nailed down. My first question when I started reading was, I wonder what is inside the engine. Later on I found out. I hope the engine holds together and you have a long and fun filled ownership!
#208
That's what I'm thinking. I ordered some more. When they come in I'll replace them and find out if that was the issue or not.
Stay tuned then, they should be coming pretty soon. I intend to get my lock grommet replaced, the interior door panel fabric fixed, the cowl grommets replaced and my shifter fixed over the next 2 week.
#210
Ill be your huckleberry
